Old 11-11-2021, 07:13 PM   #1
DancingAvocado
Horrible whining sound under hood
This is on my 72 C20 I recently got. Last owner said it sat for 12 years. I cleaned the tank and lines, put new belts, charged battery. I got it running, and I have a weird sound.
I think one of the pulleys is bad, but it I never had a bad pulley sound like this before. It was very loud. I can't feel any play on the pulleys by hand.
https://imgur.com/a/tvPV5E1 You may have to click unmute on the video, it does have sound.
DancingAvocado is offline   Reply With Quote
Old 11-11-2021, 07:17 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Horrible whining sound under hood
Bearings may be dried out in the alternator or water pump.
LockDoc
Leon
Old 11-11-2021, 08:02 PM   #3
purple gas
did you loosen the belts and try spinning some pulleys by hand?
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 11-12-2021, 12:17 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
LockDoc
I was thinking water pump, but yeah.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-11-2021, 09:05 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If you don't have a mechanic's stethoscope, you can place the handle end of a long screwdriver against your temple, then touch the other end on various parts. Water pump, alternator, PS pump...... be careful you don't touch any moving parts like belts, pulleys, or the fan. Should be able to isolate the noise.
I have also read you can do the same with a few feet of vacuum hose, but I've never tried that.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-11-2021, 09:32 PM   #6
garyd1961
You can also take the belts off and run it for a minute. If the sound goes away you know it's not internal and is something running off the belts .
garyd1961 is offline   Reply With Quote
Old 11-12-2021, 12:10 AM   #7
knuckle-nurse
I had a horrible whining sound inside my cab the other day but it went away when I dropped the cluck off at the hairdressers.
knuckle-nurse is offline   Reply With Quote
Old 11-12-2021, 06:14 AM   #8
Redneck Rydes
Redneck Rydes's Avatar
I can relate,15 hours non stop in the truck,OH MY
Redneck Rydes is offline   Reply With Quote
Old 11-12-2021, 07:56 AM   #9
Lethal Tendencies
Lethal Tendencies's Avatar
Lethal Tendencies is offline   Reply With Quote
Old 11-12-2021, 09:49 AM   #10
BigBird05
Do you have power steering? Could be low on oil.
BigBird05 is offline   Reply With Quote
Old 11-12-2021, 04:20 PM   #11
rockyrivermark
Pretty easy to diagnose when it's that bad. like others already said, pull the belts and turn things by hand.
I'd bet a 12 pack of long necks it's water pump.
RRM
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 11-12-2021, 05:57 PM   #12
Have you tried a stethoscope (harbor freight has decent one cheap). Sure makes finding the noisy item quicker than throwing money at parts.
