11-11-2021, 10:30 PM | #1 |
Lots of NP205 New Process 205 Parts
I'm cleaning up the garage, and decided to see if there's any interest in my NP205 spare parts. All parts are used.
Buyer to pay shipping costs. I work 40-60 hrs a week, so it might take me a couple days to get the parts shipped. Most items will fit in a USPS flat rate box, and I will combine shipping when possible. Prices will probably seem high, but these are genuine New Process parts and are getting hard to find. Please post interest in item(s) on the thread so I'll have a clear order to follow in case there's multiple people interested in the same item. We'll continue with PM's afterwards. Earliest buyers get choice of part(s) if I have multiple of the same item. Paypal or US Postal money order for payment. PayPal fees are included, but NOT shipping fees. If paying with a Postal money order, I'll reduce the price by the PayPal fees (2.9% plus $0.30). I'm not in need of any trades, but will consider '58-59 GMC specific parts, '55-59 Chevy/GMC parts, or '60-66 Chevy/GMC parts or '55-57 Chevy car/wagon parts depending what you have. Additional pics available. The pics are reduced to meet the max size allowed on the forum, and don't show as much detail. I can email or text higher resolution pics to someone after they post interest in a part. At this time, I don't have any TH400 large bore cases, 32 spline input gears, or TH400 adapters; it's been over 5 years since I've seen a 205 in the wrecking yard so I don't think I'll stumble across any, but will post if I do. Parts List (I'll list the bulk of it) I might not list everything, so if there's a specific part(s) you need feel free to ask. GM NP205 Shifter (All chrome shifters need to be rechromed, all painted shifters need to be cleaned and repainted) 1967-72 (I don't remember which year) used with the 4 speed manual trans - $175 1967-72 (I don't remember which year) used with the automatic trans - SOLD 1973+ cast shifter without grease zerk - $110 1973+ cast shifter with grease zerk - $120 1980+ two piece welded shifter - $150 Shift Knobs various condition - $15 to $40 depending on condition Shifter pivot bolt Without grease zerk - $35 With grease zerk - $40 Shifter S-link - $40 Shift rail joint linkage/bracket - $20 If you need a complete shifter package (i.e. all you have are bare shift rails at the transfer case) I'll work with you on a package deal. Shift fork - $15 Shift ring - $15 Shifter boot (pretty nice for used) with retaining ring and NP205 or NP203 shift pattern plate - $60 Shifter boot retaining ring and NP205 or NP203 shift pattern plate (no boot) - $30 Large shifter boot retaining ring (no boot or plate) - $20 32 spline fixed rear output shaft pre 1973 style with compression fit speedometer drive gear and shim (included) bare otherwise - $90 32 spline fixed rear output shaft 1973+ style (bare) -$110 32 spline slip rear output shaft (bare) - $100 10 spline front output shaft (bare) - $50 30 spline front output shaft (bare) - $75 32 spline front output shaft (bare) - $100 10 spline yoke - $30 30 spline yoke - $35 32 spline yoke - $40 30 spline four bolt flange - $100 32 spline four bolt flange - $100 Output large gear - $50 Output small gear - $40 Idler gear - $50 Idler shaft - $20 GM Speedometer driven gear (metal) your choice of tooth count - $40 Dodge/International one piece speedometer driven gear (metal) your choice of tooth count - $125 GM Speedometer driven gear retainer - $20 GM rear output cast housing (bare) - $75 Dodge/International rear output cast housing (bare) - $75 Rear output aluminum bearing retainer (5 bolt holes) - $40 Front output aluminum bearing retainer (4 bolt holes) - $30 Front output aluminum access cover/retainer - $20 PTO cover plate - $12 TH350 to NP205 adapter with drive coupler - $250 SM465 to NP205 adapter with drive coupler - $225 Crossmember to Adapter bolts (pair) - $7 TH350 27 spline input gear - $60 SM465 10 spline input gear - $50 Bare divorced (Dodge or International) passenger drop main case with correct 32 spline divorced input shaft - $475 Discount available if you need multiple parts. Daniel Last edited by ChevyK10Dan; 11-21-2021 at 01:18 PM. Reason: Update availability or price |
11-11-2021, 10:33 PM | #2 |
Re: Lots of NP205 New Process 205 Parts
Additional pics
11-12-2021, 12:38 AM | #3 |
Active Member
Sir,
I will take a shifter pivot bolt with grease fitting and a shifter boot if you have one for 1969-72. Please let me know how to pay. Thanks Rob |
11-12-2021, 01:07 AM | #4 |
11-12-2021, 03:20 PM | #5 |
1971 chevy blazer Shifter pivot bolt , With grease zerk - $40 shipped to 11530
11-13-2021, 12:11 AM | #6 |
11-13-2021, 12:28 PM | #7 |
6>8 Plugless........
I will take a greaseable pivot bolt, and the lower left shift knob with the white around the black letters.
Do you happen to have any 71 or 72 4 Speed 4x4 shift handles?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-13-2021, 01:55 PM | #8 | |
The threads are 3/8-24 (fine) instead of the more common (1973+) 7/16-20 (fine). I don't remember if I removed it from a GM truck or if it was from a Dodge, International or Furd, but it could have been any of them. UPDATE: it appears this style was used on Furd (NP205 & Dana 24) from 1959-77. The knob has been repainted at some point (the white looks more cream color) and done rather poorly in my opinion. The knob has a fair bit of wear on it as well, and a small chunk removed on the bottom where it threads to the shifter. If you're still interested I'd take $10 for it, and it would ship at no additional cost with the bolt. I found the one shifter I have for a 4-speed, but I believe I removed it from a 1973+ 4x4 (larger dia then the earlier ones?). I could be wrong (I haven't messed with this stuff in years) so if there's a quick way to ID I'll do my best to confirm. Last edited by ChevyK10Dan; 11-13-2021 at 02:54 PM. Reason: Updated manufacturer |
11-14-2021, 12:21 AM | #9 |
I'm in on the knob. The 4 speed shifter looks like an 80s square body one nut I'm not certain.
11-14-2021, 01:56 AM | #10 |
11-14-2021, 07:33 AM | #11 |
If you have another one of those above shifter knobs I would be interested. Dieselwrencher beat me to it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-14-2021, 11:45 AM | #12 | |
Daniel |
11-15-2021, 08:59 AM | #13 |
I'll take NP205 transfer case shifter 71-72 K5 and an S Link please. let me know how i can pay you. thanks
11-15-2021, 10:54 AM | #14 |
11-15-2021, 09:40 PM | #15 | |
A - I know is pre 1973, and probably pre 1971, but I'm not sure B - is somewhere around 1971, 72 or 73 to about mid-late 70's? C - is somewhere in the late 70's or early 80's to about mid 80's? D - is somewhere around mid to late 80's till they stopped using the 205? (It has a plastic bushing type connector on the TC side of the link. Ford - unknown year but most likely '77 or older. It is definitely Ford since it is made for the driver's side drop TC. I used to know all this stuff without thought, but it's been 10+ years and unfortunately I don't know the details like I used to. I'd recommend "B" for your '71, it's probably the correct one, and the same length as "A" if it's not the correct one. It is also stronger than the flat plate style (A is actually 3 separate pieces, with the studs pressed into the plate, and I have one that has a stud missing. "A" does have it's place for an exact restoration, for the early models that used it. I'll follow up with a PM to make sure you get the one you want. Thanks, Daniel |
11-20-2021, 10:05 PM | #16 |
Shifter package #1
Includes: Cast style grease-able shifter (was chrome but needs to be rechromed or painted) Used shift knob, with the 4 wheels and box for a transfer case on it. Non grease-able shifter pivot bolt Used shifter bolt washer New shifter bolt wavy washer (it's made in China, and the closest match I've found so far) Your choice of S-Link (A, B, C or D) see post above With new washers and new curved/spring washers (spring washers are made in US and seem to be a perfect match) Shift rail connecting bracket/plate Shift rail pins, and correct wire clips Metal shifter ring. It's been repainted, some might run it like it is, and some might repaint. Aluminum shifter location plate. It's been repainted, some might run it like it is, and some might repaint. Package deal $225 shipped. |
01-13-2023, 05:58 PM | #17 |
Hey Dan, for some reason I'm not able to send you a message. Do you have any 27 spline input gears left?
01-13-2023, 06:05 PM | #18 |
His last time on the board was 02-28-2022.
01-16-2023, 01:44 AM | #19 |
I had to pull away from hobbies to help my dad deal with some health issues.
I oddly enough just got back into selling parts. In in effort to move more parts I started listing on eBay but checked back here tonight. I renewed my subscription for a month to let everyone know what's going, and get back to the inquiries posted. Thanks Dan |
01-16-2023, 01:53 AM | #20 | |
If you are still interested I do have a couple and can sell them cheaper on here than eBay, and use the extra money to support this site. Let me dig them out tomorrow and I'll get back to you in a PM. Thanks, Dan |
01-19-2023, 11:01 PM | #21 | |
Thanks, Dan |
01-30-2023, 12:49 AM | #22 |
Interested in the divorced TC, have the input, retainer etc to go with it? 1350 or 1450? And the usual deal killer, cost to ship to 98022.
Thanks |
01-30-2023, 02:27 AM | #23 | |
I have the Bare divorced International case that's not listed on eBay yet, that I can also sell with the correct 32 spline input shaft and bearing retainer if you don't have a preference. They are both passenger side drop, the mounting bolt location is the main difference. I have a complete Dodge divorced 205 that I've been saving for a project, but would consider selling it. Shipping would probably be the deal breaker though. The bare cases are $75-$175 to ship in the lower 48, the complete case would have to go freight and I don't have an account like a lot of people so it's not going to be cheap. These divorced cases came with the Dodge style yokes that use the straps not u-bolts and I don't think they are as strong. I'll have to check what size they are but probably 1310, maybe 1350. I'll work on the shipping quote, but it will only be a ballpark without the full address. You can also check the shipping price on the eBay listing to get an exact number. I'll send you a PM after work tomorrow. Thanks, Dan |
01-19-2023, 03:40 PM | #24 |
Do you have any NP203 shift knobs left? I'm looking for one with the shift pattern on it with the highs on bottom and lows top. Id be interested if so PM me please.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
01-19-2023, 10:04 PM | #25 | |
Thanks, Dan |
