Old 11-14-2021, 10:20 PM   #1
kev2809
low n' slo
kev2809's Avatar
Brake booster/master cylinder/prop valve
I bought this stuff new a while back and it got all rusted up and has zero miles. I plan on cleaning up the booster. but I need a new master cylinder. and also am wondering is a prop valve really needed? and if so, how would I know which to get?
truck has disc brakes up front with rear drums. does the year for the master cylinder make a difference? I believe mine is a 1" bore. but I really hate the locking metal bars on the lid
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-15-2021, 12:13 PM   #2
SCOTI
SCOTI's Avatar
Re: Brake booster/master cylinder/prop valve
Prop valves are for safety as well as function once they were introduced. One can bypass them but you'll still need something to allow adjusting front & rear bias.
The fronts are usually 70% of the stopping force so something needs to be able to tune/adjust the rear. Factory prop valves are intended for factory applications (tire sizes). Once different tire sizes are used front & rear, the bias changes. Whether it's detectable or not is debatable & subjective.
Later model master cylinders will work so they don't have to be 'year model specific'. You'll want/need to use the proper bore size for the brake application. Manual brakes, power brakes, Hydraboost usually all require a different bore size. Bore size impacts pedal feel/force required. The plunger depth can also be different when using/mixing parts so you have to pay attention there as well.
My recommendation is to stick w/a kit if you aren't familiar w/this info already. Kits are usually based on a good combo of parts for a specific application.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-15-2021, 12:39 PM   #3
kev2809
low n' slo
kev2809's Avatar
I read your info on the adjustable prop valves and that's probably the way I will go. I was digging around oreillys website and found the 73 master cylinder with the same 1" bore. I bought this stuff brand new from there and have no idea what route I went the 1st time.
I also have the 2002 tahoe booster and master cylinder assembly on my parts truck I could rob, but I haven't even started looking into that
-_--_--_ _________
Old 11-15-2021, 08:56 PM   #4
68 P.O.S.
Food for thought...1-1/8" bore is normally for power brakes, but it seems some of these trucks did come with a 1" bore MC with PB. No idea what the difference would feel like between the 2.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 11-16-2021, 07:57 AM   #5
kev2809
low n' slo
kev2809's Avatar
the problem is this stuff I pulled off, I bought it brand new from oreillys. I just don't remember what the hell I bought back then (as in what application I told them). I'm really thinking I told them 73 c10, because that's what my pads and rotors are for
-_--_--_ _________
Old 11-16-2021, 10:33 AM   #6
SCOTI
SCOTI's Avatar
  • Prop valve would likely be 71-72 since it appears to be one of the units that's mounted next to the master cylinder. The Squarebody generation prop vale was moved to the front lower splash-shield between the rails in front of the motor.
  • I would imagine 71-72 for the vacuum booster unless it has an integral mounting bracket (71-72's don't; 73-up do).
  • Master cylinder could be from any early model but again I'd guess 71-72 because of the cap retainer clips & for disc brakes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-16-2021, 09:31 PM   #7
68 P.O.S.
Your combination valve looks like the Bendix 411, which was stock for these trucks.
Your MC is a newer "universal" model that works for disc/drum or disc/disc applications. Will work fine on your truck.
I have no idea on the booster. Looks right tho.
Old 11-15-2021, 11:09 PM   #8
MikeB
MikeB's Avatar
The stuff was new a while back, and then sat outside for 20 years?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-16-2021, 07:55 AM   #9
kev2809
low n' slo
kev2809's Avatar
ha! just about. I put it on the truck about 7 years ago? maybe less. I never put a coating on it. I rolled the truck out the garage and I got burnt out and didn't work on it much. drove it down the street once. so I pulled everything back off to actually paint it (front frame, suspension, etc.). the booster seems fine, but the master cylinder rusted inside too where the holes are. I don't trust it.
-_--_--_ _________
Old 11-16-2021, 11:14 PM   #10
kev2809
low n' slo
kev2809's Avatar
the 72 master cylinder is listed as a 1.13 bore...I used some cheapo HF calipers and I got 1.10. so I think the 72 is spot on. I don't see anything "bendix 411" though
-_--_--_ _________
Old 11-17-2021, 08:15 PM   #11
kev2809
low n' slo
kev2809's Avatar
these are the brackets for the booster
-_--_--_ _________
Old 11-17-2021, 11:11 PM   #12
SCOTI
SCOTI's Avatar
Those are the 67-72 adapter brackets for the vacuum booster.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-20-2021, 11:07 PM   #13
kev2809
low n' slo
kev2809's Avatar
ya I'm pretty confident I went 72 booster, cylinder, and prop valve.
thanks scoti
-_--_--_ _________
