![]() ![]() Join Date: Jan 2005
WTB - 3 Groove Crank Pulley for SBC with Short Water Pump
I've currently got a two-piece two-groove crank pulley setup, and I'm looking to go to three grooves so I can add A/C. I believe I only need a new inner pulley with two grooves to go with my current outer single-groove piece. Please correct me if I'm wrong.
![]() Join Date: Mar 2010
Re: WTB - 3 Groove Crank Pulley for SBC with Short Water Pump
I hope this helps. The part number is 3744043 this is the 2 groove pulley. Still can be purchased thru GM. Can also be purchased on EBay. If you need more help let me know I have this pulley setup on my 72 with factory air. Thanks Don
Thank you! I'll order a new one.
The other pulley #3751232 would be the power steering pulley single groove. That should you there. Don
Do you think my existing single groove crank pulley for my PS will work with the double groove pulley?
#6 | |
Always on the hunt...
![]() Join Date: Sep 2006
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
![]() Join Date: Mar 2018
Is this also the correct parts for a 68 w/ps and factory air? Short water pump.
The pulleys arrived safely. Thank you for your help.
-Patrick |
![]() Join Date: Feb 2005
I also am looking for a double groove crank pulley as well as a 3993325 p/s pump pulley
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
#10 | |
Great thanks!
