![]() Join Date: Nov 2019
250 Power Steering Pulley Help
I have been slowly cobbling parts together to add power steering to my 1969 GMC with a 250 cid. I thought I had found the correct pulley, but after installing it, it is off about 1/2" - 3/4". The PN on the pulley I have is 354324AB.
I'm hoping someone smarter than me will chime in and tell me I need ****** pulley and you can get it at (insert web site here) ![]() Any help is greatly appreciated. ![]() ![]()
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
![]() ![]() Join Date: Jul 2002
Re: 250 Power Steering Pulley Help
Looks like that is for the later model 250s. There is a bigger space on the crank pulley between 1st and 2nd pulley groove compared to the earlier ones. This is what mine looks like before I hooked all the accessories to engine (77 era block).
I currently have custom aftermarket brackets on mine, but your power steering bracket looks like it is for the later model integrated head which would push it out like that too. Hard to tell since I no longer have factory accessory brackets. NOTE: 2nd picture is mine when stock, the steering pulley went to the 3rd, crank pulley, AC was 2nd and alt was first pulley.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-26-2021 at 10:38 PM. |
Check these 2 pulleys from Rockauto. One is a double pulley and the other is a set back pulley, supposedly for a I6.
https://www.rockauto.com/en/moreinfo...t=7381&jsn=603 https://www.rockauto.com/en/moreinfo...t=7381&jsn=605 |
![]() Join Date: Dec 1999
Those Lares pulleys look like they will work.
Here's where I had the same problem. Start at Post 20 - http://67-72chevytrucks.com/vboard/s....php?p=7972779 I show what pulley I ordered on post 29 - http://67-72chevytrucks.com/vboard/s...9&postcount=29 |
#5 | |
The Lares 165 pulley also states it's the same as GM # 3834720.
![]() Join Date: Aug 2019
Are you sure you have the right pump? I thought our models used the bolt on pulleys? Your picture shows you using a press on tool?
It is a bolt on.
I have another complete set of brackets that has a pump with press on pulley(same PN 354324AB as yours). I have never had it on an engine so I don't know if it lines up. I also have another press on DOUBLE pulley, that when I hold it up to the single like yours, seems like it would put the 2nd groove a full groove closer to the engine. Not sure PN. I think I got it in a batch off this message board, but can't find where. My working setup is double groove alternator with PS belt on outer groove. |
I was looking at your pictures and it appears you are using the brackets like shown in the middle row of my post
![]() Middle Left - 354527 Middle Right - 355789 My pump that has the pressed on pulley like your also has those same brackets. On my setup with the bolt on pulley it uses the ones from the top row. That may be the difference in those brackets. Are you sure you have the pulley pressed on all the way? Those pictures you saved from 1968C30 (https://67-72chevytrucks.com/vboard/...d.php?t=825218) look like the pulley is pressed on more. |
#10 | |
![]() It appears that I have the bracket on the top left and the adjuster bracket middle right.
If you look at bonestock3ott's pictures closer it appears he's got the pulleys with the gap in the middle he's using with his pressed on pulley.
Example image from another thread: ![]() |
The pulleys on my motor do not have the gap between the two grooves like the picture above.
#13 | |
The Older Generation
It looks like you have the long snout pump on yours. When I put the PS setup on my '67 I6 I ended up using the short snout pump & everything lined up OK. LockDoc
![]() Join Date: Jun 2005
This is what I did as well. Replaced the pump with a bolt-on pulley type and reused the later reservoir and everything lined up. Also used the double-groove alternator pulley like mentioned earlier.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#15 |
![]() Join Date: Jun 2000
Can you give some details on what is a long snout VS a short snout pump? I've never heard of this before. Thanks
#16 | ||
LockDoc
#17 |
Looking at your picture above, it looks like you have the middle left bracket, not the first row left bracket.
My guess is, without having the balancer and the water pump pulley that have the gap in the middle, it won't line up. Things you could try: Double press on pulley(not sure which one) Pump with bolt on pulley(not sure which one) edit: I was working on my response when lockdoc replied. Locdoc have you got part numbers or vehicles that use the different types? |
#18 |
I've been looking at power steering pumps online and can't find anything referencing different lengths of snout on the pump housings.
I'm convinced that the pumps with the press on pulleys were designed to line up with the different balancer and water pump pulleys that have the gap in the middle. I did a quick look on ebay and the balancers are available, but didn't see any of the water pump pulleys. Seemed like it was easily gonna cost a couple hundred dollars to go that way. I'd try a 2 groove press on pulley like this: https://www.amazon.com/Dorman-300-12.../dp/B000E321ZU That's the cheapest I could find it. Also known as GM PN 14084343 if you want to look. Thought it might be better to pay more and buy locally so you could return it, if it didn't work. |
#19 | |
#20 |
I just went and got it and realized it does have a part number 354325 - there are many for sale on ebay if you want to see what it looks like.
I'll send you this one though. It looks like someone used pliers to try to get it off the pump, that's where it's chewed up. |
#21 | |
I had to put a double pulley on the alternator, which fortunately I already had, and the outer groove sticks out farther than any other groove on my motor, but it works and that's all I was looking for. ![]() ![]()
#22 |
Send me your address and I'll send you this double press on that I have. It's kind of beat up, but would let you know if it works...
#23 |
PM sent.
#24 |
I guess I wasn't explaining why I think the double pulley will work. I also have a single pulley like yours and the outer groove on this pulley lines up with the groove on it and the 2nd groove is closer to the engine.
