Old 11-30-2021, 01:29 PM   #1
eric8
M/T column shift rods
Anyone know where these are available aftermarket? No luck with LMC. I need the larger diameter one seen here for my 77 C10 2wd.
eric8 is offline   Reply With Quote
Old 12-01-2021, 04:36 PM   #2
Re: M/T column shift rods
They are not reproduced. You'll have to find someone with a used set that they no longer want.
Old 12-02-2021, 12:23 AM   #3
44th Miss Inf
Is that 3 on the tree shift rod you are pointing at? (I can’t see it that well on my phone)
If so, i have a 76 model set if thet will work.
44th Miss Inf is offline   Reply With Quote
Old 12-02-2021, 11:05 AM   #4
eric8
Yes that is correct. It’s called the first/reverse lever and it’s the larger diameter one of the two. If I’m reading the parts catalog correctly, as long as the rod you have came from a 76 model that was originally equipped with a V8, it should work! If it was originally a 76 with a 6 cylinder then it looks like it may be a different part number.
Old 12-04-2021, 03:54 PM   #5
44th Miss Inf
I haven’t forgotten you, just haven’t had time to go to my other place and look as I have been tending to my wife who has pneumonia. Should be able to get away to check in a day or two, as she finally starting to turn to the better
Old 12-04-2021, 04:08 PM   #6
eric8
Ok no problem, it’s no rush. Thanks again.
Old 12-07-2021, 07:21 PM   #7
44th Miss Inf
Eric8,
Sorry, the only thing that I could find with the linkage still intact was a 6 cylinder truck
Old 12-07-2021, 09:20 PM   #8
eric8
Eric8,
Awww man….well thank you for checking anyway!
Old 12-13-2021, 10:04 PM   #9
eric8
Anyone else?
Old 12-14-2021, 12:13 AM   #10
geezer#99
geezer#99's Avatar
If you can’t find one have you considered bending a new one.
What’s wrong with the one in your pic?
geezer#99 is online now   Reply With Quote
Old 12-14-2021, 11:31 AM   #11
eric8
Mine broke on the end that attaches to the transmission. I can still hook up the linkage, but there’s not enough of the rod left to get a good adjustment. Fabricating something like that would be way beyond my capabilities. It transitions from round hardened steel to flat stock up by the shifter. Plus you’d have to fabricate the rod end that holds the shift bushing.
Old 12-14-2021, 12:17 PM   #12
geezer#99
geezer#99's Avatar
Take it to a welding guru.
They can put an end on your linkage that you’ll need.
