Old 12-08-2021, 03:31 PM   #1
elorenzof
Subwoofer to battery cable routing
I was wondering, I'd like to run my subwoofer to battery power cable thru the fresh air vent on the passenger side to run it between the inner and outer fender / keep it tucked up so there's less of the power cable to be seen. I have a vintage air ac kit, and it comes with a plate to cover that factory passenger side vent hole as im pulling my factory ac unit and such on the firewall out. would this be doable?
elorenzof is offline   Reply With Quote
Old 12-19-2021, 10:16 PM   #2
Peanut74
Re: Subwoofer to battery cable routing
Anything is doable if you put your mind to it. But rather than running the wires up and out the fresh air inlet why not down through the bottom of the fresh air inlet. That is how I run my Vintage A/C wiring, washer pump, etc. The wires are all hide like you want.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
