12-21-2021, 10:46 PM | #1 |
66 C10 Stepside Remote Fill Ideas Wanted
I have my Boyd tank installed in the rear
I dont want to come up through the bed floor Any ideas installing the fill on the bed fender?? Posted via Mobile Device |
12-21-2021, 10:56 PM | #2 |
But Found Her 25yrs Later!
Re: 66 C10 Stepside Remote Fill Ideas Wanted
There are a couple cool threads on this.
I'll see if can find one.
12-21-2021, 11:07 PM | #3 |
http://67-72chevytrucks.com/vboard/s...d.php?t=765224
https://67-72chevytrucks.com/vboard/...d.php?t=732404 http://67-72chevytrucks.com/vboard/s...d.php?t=576943
12-21-2021, 11:15 PM | #4 |
If I decide to move my tank to under the bed, I plan on using a 60-66 suburban or panel filler neck and fuel door in the bedside. Welding and body work definitely involved with that idea though
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-21-2021, 11:33 PM | #5 |
I found this filler neck and cap
1.5 inch filler neck I could go on the fender top with a 2.5 inch diameter footprint. I could bend and weld some aluminum hard pipe from this filler neck and trail beneath the fender well then 90 over with a 1.5x2 reducer fuel hose and then connect to the fuel tank filler pipe which on mine is directed towards the bed side Looks this may be a clean install and abit custom. Thoughts? Last edited by Afirehawk1; 12-22-2021 at 12:36 AM. Reason: Typo |
12-22-2021, 12:19 AM | #6 | |
12-22-2021, 12:37 AM | #7 |
Sorry, my suggestion earlier probably won't work too well on the stepside fenders. Should have read the title a little clearer.
Here is what Roll_the_dice did for his stepside: http://67-72chevytrucks.com/vboard/s...&postcount=327
12-22-2021, 07:15 PM | #8 | |
Moderator
12-22-2021, 10:44 AM | #9 | |
1–creativity 2 — wallet size Remember you are building this to please yourself, the rest are just lookers😉😉😉 |
