12-27-2021, 10:01 PM | #1 |
To replace or not, rear brake cylinders
I replaced rear brake cylinders, with the front also, in July 2015 when I got truck. The rear shoes were pretty good at the time. Will be replacing brake shoes and not sure if the cylinders should be replaced this time. By the time I get to it, they will almost be 7 years old. Haven't done a complete rear brake job in many years. Thought I may need to go ahead and replace, but wanted opinions.
TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
12-28-2021, 12:40 AM | #2 |
Re: To replace or not, rear brake cylinders
Unless they are leaking there is no need. Just keep an eye on them.
Unless you have a spare set in your toolbox or money is no object, that is.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
12-28-2021, 08:26 AM | #3 |
What he said
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
12-28-2021, 10:09 AM | #4 |
You don’t need to replace the cylinders (maybe), but you should inspect them. Easy to pull them apart in place and check the bore. Use a piece of super fine emery cloth and give them a quick clean.
If you find any excessive pitting you should get new ones. |
12-28-2021, 12:35 PM | #5 |
How old is your rear brake hose?
Take lots of pictures before you start. |
12-28-2021, 08:11 PM | #6 | |
I do not know how long since they have been replaced, or if ever. I did not replace the rears in 2015.
