Old 12-30-2021, 06:22 PM   #1
69Tom
69Tom's Avatar
rebuilding 74 fuel selectors valves
So I'm rebuilding my dual tank fuel selector valves (aka Selectrol 6795) on my 74 C20. So far so good. Have them cleaned up, got rid of any rust, got new rubber O-rings for the selectors, and now I'm ready to re-assemble.
Question is here: lubrication for the selector arm shaft and then the contact on the metal plate to help the selector slide from side to side.
While it should now move much easier now that I have it cleaned up with new O-rings, I'd like to apply some lubricant, at least to the shaft arm. I'm thinking lithium grease should be fine, as I kind of doubt it's exposed to much fuel. And then I'm thinking there's not much I can do about the metal plate contact, other than polish it so it slides better, which I did.
Thoughts here?
69Tom is offline   Reply With Quote
Old 01-05-2022, 02:02 PM   #2
1774btcrew
1774btcrew's Avatar
Re: rebuilding 74 fuel selectors valves
Definitely let me know how it works after your rebuild! I may have you locked me through your building one of mine
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 01-05-2022, 02:05 PM   #3
69Tom
69Tom's Avatar
At present, I can tell you be very careful with the valve plunger/stopper screws. They are very small and break easily. I broke mine over torqueing it. I had to locate a whole new unit just for that part. I have been told you can JB weld it, but I don't really like JB weld.
Other than that, seems to be going ok. I guess the next check will be to see if the gasket maker actually works. Not like you can find original gaskets for these things.
Old 01-07-2022, 05:18 PM   #4
69Tom
69Tom's Avatar
So far, so good. Just need some more gasket material to make one gasket then I can button them up and reinstall.
Old 01-13-2022, 07:32 PM   #5
69Tom
69Tom's Avatar
Turned out great. Smooth action. Bought correct fuel gasket material and made mine off the template in the pic above. Looking forward to getting it back on the truck and trying it out.
Old 01-15-2022, 09:23 PM   #6
1774btcrew
1774btcrew's Avatar
that looks really nice! Good work!
Old 04-01-2022, 05:04 PM   #7
jasmcb
New Member
Tom I sent you a private message. How did the rebuild turn out on your Selector Valve?
jasmcb is offline   Reply With Quote
Old 04-01-2022, 05:19 PM   #8
69Tom
69Tom's Avatar
I've only used one tank so far as the truck is not yet back on the road, but that tank works great.
Old 04-01-2022, 05:36 PM   #9
hatzie
Moderator
hatzie's Avatar
I added a link to this thread in the dual tanks theory of operation thread under the 1973-75 manual valve section heading in post #1.
Nice work BTW.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-05-2022, 12:18 PM   #10
LT7A
That's cool. Good work.
Old 04-05-2022, 06:42 PM   #11
69Tom
69Tom's Avatar
For those who wanted "before" pics, I found a couple. Wasn't in horrible condition, wasn't in great condition.
Old 04-05-2022, 06:45 PM   #12
Warrens69GMC
Warrens69GMC's Avatar
Wow, good job!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-02-2022, 06:42 PM   #13
69Tom
69Tom's Avatar
I thought I should give a quick update here. I ended up pulling my selector valves and they were slightly leaking. I believe a bead of fuel resistant sealer is going to be required in addition (or instead of) the lid gasket. I will probably still use the gasket and add sealer. For the time being, with gas at well over $5/gal here, I'm just going to use the one tank. If gas ever goes down, I'll put it back up on the rack and reinstall it. For now, I'm tired of restoring stuff, so I'm just going to enjoy driving the truck 5 miles at a time. Stupid gas prices....
