Active Member
![]() Join Date: Sep 2010
ISO: temp wire & terminal from dash cluster
Hoping someone has a parts truck that they could remove the temp wire & terminal from the connector plug to send me. Mine is missing from the connector and the terminals are only sold in min. Qty of 28 online. Hoping I can just plug an old one into the connector and solder my cut temp wire to it. Thanks -Mike. (67 C10)
![]() ![]() Join Date: Jan 2005
Re: ISO: temp wire & terminal from dash cluster
If you are upgrading your gauge cluster from a 3-hole style with warning lights to a 7-hole style with gauges, then you need to rearrange the pins on that connector. You will not need to add a pin. See this thread for more information.
http://67-72chevytrucks.com/vboard/s...d.php?t=645940 |
I can mail you a single connector pin with a few inches of wire attached if that will help you. I would cut it from a junk original harness I have. Let me know.
Active Member
That would totally help. I’m just trying to avoid paying $30+ dollars for the whole setup when I only need 1 terminal : ).
I’ll pm you and we’ll see if we can work something out. Thanks again |
Active Member
Not switching to 7 hole- it just seems that someone had removed the temp wire from the plug for some reason (my temp gauge didn’t work and my google search showed that the #5 slot was for the temp gauge)
Here's a photo of the terminal/wire I'll mail to you today. By the way, it is normal for pin 5 of that connector to be empty on a truck with a temperature gauge. The temperature gauge is the dark green wire on pin 6.
Active Member
That’s good info, thank you. I saw one that showed it on 5 and another that showed it on 6. I’m definitely an amateur at all this and always learning : )
#8 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=185856 The terminal is in the mail, by the way. Hopefully you won't need it. |
