01-11-2022, 07:03 PM | #1 |
GM 8 Cylinder Tachometer in GM Box
OEM Tach
V8 Untested Comes in Original GM Box $125, plus shipping
1964 C-10 SWB Fleetside 6cyl/ Stick 1968 C-10 SWB Fleetside 355/Turbo 400 1970 GMC 5500 Dump Truck 401 V6 1971 K5 Blazer CST 4WD 350/ 350 1971 C-30 Longhorn 350 / 4 Speed 1972 K-10 SWB Fleetside 350/ 4 Speed 1972 GMC SWB Fleetside 6cyl/ Stick 1979 K/10 SWB Fleetside 350/350 |
01-11-2022, 07:24 PM | #2 |
DND Trucks
Re: GM 8 Cylinder Tachometer in GM Box
Got a couple questions on this. Does the tach have any evidence of mounting to a instrument cluster around the screw holes? Also, do you have any pics of the back of the tach face? Thanks.
01-11-2022, 09:05 PM | #3 |
I’ll get inline for this as well
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
01-11-2022, 09:32 PM | #4 |
It sure looks as if was mounted in a truck. So I’m guessing this is used and not NOS?
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
01-11-2022, 09:34 PM | #5 |
You can see where it has been mounted
01-11-2022, 09:36 PM | #6 |
NOS was never mentioned, or implied.
Lets be clear on that. -Mike
01-11-2022, 09:41 PM | #7 | |
Thank you
01-13-2022, 07:29 AM | #8 |
DND Trucks
Mike, do you have way to test the tach with a multimeter or otherwise? I can explain how, it's very easy under a minute.
