Old 01-22-2022, 08:36 PM   #1
bluec10
bluec10's Avatar
Need help bleeding brakes
I installed a new brake booster and master cylinder and need to bleed the brakes.I bench bled the master cylinder - it wasn’t a new one but it was only used for a few hundred miles.
I put my vacuum pump on the right-rear brake and pumped up to 20psi pressure. No fluid came out after a lot of pumping. The mc is full of fluid.
The bleeder screw was well open.
Any ideas?
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 01-22-2022, 08:41 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Need help bleeding brakes
It has a dual master, right? Perhaps you triggered the shuttle valve? I'm guessing that you're working on the '69 in your signature?
~Steven
Simi Valley, CA
Old 01-23-2022, 12:07 AM   #3
Accelo
Accelo's Avatar
Did you bench bleed the brake master cylinder? I always do this to confirm everything is working correctly.
I also leave the lines loose at the MC and pump the brakes till I get some seepage at the joint then I fully tighten the fittings.
Pump the brakes, see it that works. If not, it is easy to get the rod between the pedal and the MC out of adjustment when retrofitting brakes. As in it could be too long. Confirm you have some slack there.
Accelo is offline   Reply With Quote
Old 01-23-2022, 12:16 AM   #4
Getter-Done
Getter-Done's Avatar
Did you try (pushing or pulling) the button on to proportioning valve?
The early bird gets the worm,
84 Chevy K-20
Old 01-23-2022, 02:29 PM   #5
jimijam00
If you remove the vacuum pump, open the bleeder, and push on the brake pedal, does any fluid come out?
The second sentence of his post stated he did.
jimijam00 is offline   Reply With Quote
Old 01-23-2022, 03:06 PM   #6
Accelo
Accelo's Avatar
Oops, thanks for the correction
Old 01-23-2022, 02:04 PM   #7
Jason Banks
Jason Banks's Avatar
Just throwing this out there. I had the same problem, turned out to be the original rear brake hose from frame to diff was blocked.
Jason Banks is offline   Reply With Quote
Old 01-23-2022, 04:07 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
That's a good point. An easy way to verify would be to close the open bleeder and hook the vacuum pump to the other side. Of course, if it has the shuttle valve and it has moved, switching bleeders won't help. When the right front wheel cylinder on my truck started leaking, I just went to disc brakes (and rebuilt the front end, which it probably needed at 210k miles). No idea how old the rear hose was, so it was a no-brainer to change it out.
~Steven
Simi Valley, CA
Old 01-23-2022, 07:16 PM   #9
kaycee
kaycee's Avatar
Pull your bleeder screw all the way out and see if the hole is not plugged, you wont loose any fluid if you put the cover back on the MC .
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 01-24-2022, 09:20 PM   #10
Chevy Fan Always
Chevy Fan Always's Avatar
Make sure the button is pushed in on the proportion valve, you can use a c clamp. There is a tool made for it. In forbleeding.
1972 Highlander Custom 10
Chevy Fan Always is offline   Reply With Quote
bleeding, brakes
