01-28-2022, 12:05 PM | #1 |
changing spindles
I am going to install QA1 front coil-over kit. From what i understand do to ball joint size i need to use a 73+ drop spindle. I have a 71 with front disk. Will this be a straight swap?
01-28-2022, 12:30 PM | #2 |
Re: changing spindles
Yes. Qa1 front requires 73+ Spindle. Also you will need two73+ outer tie rod ends to fit the spindle. Are you trying to reuse the stock brakes?
01-28-2022, 02:50 PM | #3 |
i have upgraded to a set of willwood brakes on my my truck i was hoping to reuse them.
01-29-2022, 03:51 AM | #4 |
Depending on your budget. I went with the 73+ cpp modular spindle. I really liked the wilwood pro spindles in aluminum but couldn’t justify the $
