71 Tac Question
I have not been here for a long time. hope someone can help with my problem. I have a 71 with a HEI distributer. I ruined two tac's before I found out the original tac's will only work with a point distributer. Does anyone know if someone makes a Tac that will work with the HEI distributer or if there is a way to make the original still work with it? Thanks for any help,
Re: 71 Tac Question
I am an old guy and not to tec smart. I did a search and found posts that talk about a tac resister or fuse from newer cars does that fix my problem? Thanks for helping.
#3 | |
The Older Generation
Re: 71 Tac Question
Not sure where you read that information. I have used at least 5 original tachs with HEI distributors with no problems, both 6 cylinder and V8. I would say you have some other problem with your electrical system causing the problem or you are not getting it hooked up correctly. Even if you added a resistor it wouldn't cure the problem you are experiencing. LockDoc .
![]() Join Date: Dec 2013
Re: 71 Tac Question
Truck shop - ebay listing
ONE NEW TACHOMETER FOR YOUR 1967 THRU 1972 CHEVROLET GMC TRUCK, WILL WORK WITH POINTS OR HEI IGNITION SYSTEMS. WE ARE THE MANUFACTURER AND YOU ARE BUYING DIRECT. SHIPS TO LOWER 48 STATES ONLY. https://www.scribd.com/fullscreen/57...jcbazlklxtunnw
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-19-2022 at 12:36 PM. |
#5 | |
Re: 71 Tac Question
![]() ![]() Join Date: Jan 2005
Re: 71 Tac Question
I have also run both original and reproduction tachs with HEI without any issues. That being said, I have seen these filters listed for sale on various websites. I haven't ever used one, but the warning below is somewhat intimidating.
https://www.classicparts.com/mobile/...ctinfo/24-736/ |
Re: 71 Tac Question
Thank you all for your replies and help. I have an aftermarket wiring harness (I think it is Painless but I bought it several years ago) and the dash guage unit is the repo from LCM. I burned up two Tac's and figured I needed to find someone smarter than me for help. I called LCM or the supplier I do not remember which and they told me the original tac would not work with HEI.
![]() ![]() Join Date: Jul 2002
Re: 71 Tac Question
I have a factory tach and it is not right with the HEI. Have tried the resistor thing shown and it is still off. I have heard some folks they will work and others can never get them accurate. Mine is close on low RPMs, but the higher up the more off it gets. Like today, with a 3.08 gear rear, it showed me doing 3500 RPM's at 70 MPH, but at idle it seems accurate. I am building a custom dash anyways, so I'll eventually replace it with one that is more accurate
![]() Join Date: Dec 1999
Re: 71 Tac Question
Years ago when I first acquired the cluster I am now using. I took it to a local speedometer repair shop and had them check the gauges, told them that I had an HEI distributor. Don"t know if they adjusted anything. But it works well. It was originally in a C-60.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#10 | |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 71 Tac Question
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Re: 71 Tac Question
I would call these guys. https://www.cajuntachshop.com/ Not only can they repair your tach but I bet they can make it work with an HEI distributor too. I bought a 6 cylinder board from them and installed it in one of my non working V8 tachs. Worked good in my '67 with a 250 I6. Knowledgeable people. LockDoc
