![]() Join Date: Nov 2013
Brake lights
My brake lights are on when the ignition is on. I just added power brakes. No fluid in master cylinder. Where is the brake switch located ? Do I have to bench bleed the master cylinder and the lines before the lights go off ??
Re: Brake lights
The brake switch is behind the brake pad lever. If the brake lights are on, it's probably because the brake pedal is laying down too low. Did you have to adjust the brake actuator rod (the part that goes through the firewall)?
Edit: The brake lights shouldn't be routed through the ignition switch. They should come on any time the brake is depressed, whether the ignition is on or not.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: Brake lights
X2 truckster's response.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
![]() Join Date: Aug 2019
Re: Brake lights
Well y'll beet me to it.
Well I put the tumbler in the ignition And and the taillights are off. I don't know if that was the problem. I still can't find the brake light switch or the wires that you use to connect to the switch.
![]() Join Date: Mar 2003
Re: Brake lights
Under the dash, follow the brake pedal arm up, then look for a switch with white and orange wires going to it
