best way to plumb hydrobooster & power steering?
I am looking for lines to plumb my hydrobooster and power steering on a 69. The components i have are a 2009 GM booster, 2009 GM pump, and 86 steering gear, so all should be metric fittings.
Ive read about some using stock lines from a 01-05ish GM truck/suv, but i think those are all square body guys. Im not opposed to stock lines if they fit, or even using adapters to go to AN style fittings and lines. What i am opposed to is spending $400 on a kit like i am seeing while searching online. Any suggestions other than the $400 options are appreciated.
69 C10 fleetside long bed - 6.0/4l80E in progress |
All about them K’s
![]() Join Date: Jun 2014
Re: best way to plumb hydrobooster & power steering?
I used the pump to booster line from a late 70’s K30 and the Booster to box pressure line from the 09 I robbed the booster from. The return from the booster to pump was from the 09 and the return from the box to pump was just a foot or 2 of oil resistant hose. I used the OE pump and box for my 72 with an 09 booster so I had to cut, replace the fitting and re flare the box side of 09 booster to box line because I needed standard fittings on the box and pump. Since you are all metric you’ll want to use a later pump to booster line as the late 70’s stuff will still be standard but a 80’s K30 or diesel line should work. I also Tee’d the return lines because I’m using the single return 72 pump.
So I guess what I’m saying is you should be able to find off the shelf OE replacement lines that will work for WAY less than $400.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 03-05-2022 at 11:21 AM. |
Hoses can also be made... My old auto parts store used to make them, HD truck supply stores were also another source I used as an automotive tech.
Some stores may have the fittings you may need, or you may need to supply your own. The hose itself comes in rolls, just need the HD crimper machine. Posted as second idea in case you find your self with a mis-matched fitting or a hose that just does not work for your application. Bob |
![]() Join Date: Mar 2003
There are only 2 lines that are pressure the other 2 are return low pressure. You can make those without any crimping. The high pressure hoses shouldn't cost more than 50-60 bucks each. The return lines have to hook to the reservoir correctly otherwise they'll foam and burp out constantly. don't know why but that happened to me on my dads truck when I rebuilt the 6.5T
At the body shop.
Your Pump have 2 returns to the reservoir ?
" That didnt make it any newer " " Dont antique the equipment " |
Talking to me?.........Yup
At the body shop.
The OP actually. Had a terrible time with a T return line on my brother's truck. Ended up changing to a 2 line return pump
OP here - i do have a 2 line return
All about them K’s
I had a hell of a time at first bleeding it out with mine until I figured out I needed to add fluid while it was running even after it seemed it had primed the system; ie I had some steering assist. It was cavitating some still and foaming the fluid even though it had assist. Added some more fluid to it with it running, didn’t take very much but that did the trick. I haven’t had a problem since.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#10 | |
At the body shop.
It bled fine. But if you would brake in a turn it would blow the T fitting apart. Did it once in my driveway. Nothing like re plumbing and hot PS fluid running down everything.
I have not done it, but I would have thought early 80s C30 square body lines should be really close?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#12 | |
Cheers!
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
#13 | |
And the line from the booster to the gear (on the gear end) is not bent correct. Unless I'd start hacking away at the steel fender well, I don't see how it can fit...
#14 | |
All about them K’s
| Bookmarks |
