03-11-2022, 12:50 PM | #1 |
Re-Positioning of Fleetside Truck Bed
My '72 C-10 Longbed Fleetside recently got hit in the left rear, behind the rear wheel (driver went thru red light). Besides the obvious damage, I noticed that the front of the bed is now not lined up with the cab. It is about 1/2 Inch over more that it should be. My question is, if I loosen all the bolts would there be enough play to move it back over before I re-tighten them again?
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
03-11-2022, 01:01 PM | #2 | |
Re: Re-Positioning of Fleetside Truck Bed
03-11-2022, 01:34 PM | #3 |
Although possible, I doubt I have any frame problems, although we will find out in time. I believe the bed just got jolted over a bit. And yes, her insurance will cover all the damages and so far so good, they are being very co-operative.
03-11-2022, 01:37 PM | #4 |
What does the body shop say??
03-11-2022, 01:51 PM | #5 |
He hasn't seen it yet, but will be soon. He will be doing some of the work, I'll be doing the rest myself.
03-11-2022, 01:55 PM | #6 |
Loosening the bed bolts and trying to shift it is definitely worth a try. I would make sure that it does not compromise the insurance pay out before I did, however.
I doubt that a truck bed has a full inch of slop, meaning...a half inch to the left of center plus a half inch to the right of center, but depending on where your bed is compared to the overall slop, you could get it to move the 1/2" you need.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
03-11-2022, 03:14 PM | #7 | |
03-11-2022, 03:47 PM | #8 |
Don't take it back from the body shop before it's been checked on a frame machine , DON'T settle with them until it's fixed , Insurance companies are always quick to offer a check when they know it's gonna cost them a lot more than they are offering . Just straightening the bed won't make it drive down the road straight and if it's bent you'll be buying tires faster than your last girlfriend dumped you !
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-11-2022, 08:23 PM | #9 |
a lot of good advice in this post,can you post us some pictures to see how bad the damage is overall.i agree to make sure everything is ok with a shop of your choice, another thought is how rusty the bed mounting bolts may be where they pass through the cross sills, I have seen them where they looked ok on the top side and where all but corroded away where they pass through the lower side.that may have allowed them to give and let the bed shift slightly to one side, just something else to check. either which way make sure its good in every way, before you settle, its amazing how far collision damage can reach into a vehicle and be hidden from the eye
:chevy |
03-11-2022, 10:53 PM | #10 |
Appreciate all the replies.
03-12-2022, 12:41 AM | #11 |
If the bed actually shifted on the frame you'll be able to crawl underneath and see marks on the bed ribs where it used to sit
1970 k20 6.0l/nv4500/np205/14bff in progress build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014 |
03-12-2022, 01:11 AM | #12 |
