Old 03-13-2022, 09:25 AM   #1
Gregski
Gregski's Avatar
How do I flatten the top of the frame rail?
I am looking for advice on how to flatten that raised section of the top of the front passenger side frame rail. Correct me if I'm wrong, but I believe it is there to accommodate the lower radiator hose. Regardless I am converting my '69 to an electric and have plans to set a battery pack atop the frame in that section so I would like to make it flat like the other side.
I hope these picture convey what I am trying to accomplish.
Thank you in advance,
g
Gregski is offline   Reply With Quote
Old 03-13-2022, 09:32 AM   #2
LONGHAIR
Re: How do I flatten the top of the frame rail?
I'm thinking that this is a "take your pick" kind of thing.
A little heat and a hammer/dolly
Trim most or all of it away. Saw, whizz wheel, torch, plasma cutter, etc
No heat and more hammer. To get it truly flat, you might need to cut a slit or two into it, to give the metal somewhere to go, then weld them back closed.
Grinder
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-13-2022, 09:46 AM   #3
Gregski
Gregski's Avatar
Grinder
thank you so much sound advice, especially this part:
I have minimal metal working experience but yes I have cut relief cuts in sheet metal before in order to return it to it's original shape after it was stretched out sort of speak
Do you think using heat and large C Clamps of sorts would pull it down into submission, and not pull the bottom (non heated) part of the C channel up?
Along those lines I thought of putting some sort of metal bar on top of it then clamping that down, but then I wonder how I would heat up the frame (maybe upside down with the torch) but then the metal bar would act as a heat sink? here I go again over thinking stuff, ha ha
also considering picking up this 48" pipe wrench off of Craigslist to use as leverage
thanks again
Old 03-13-2022, 10:15 AM   #4
Redneck Rydes
Redneck Rydes's Avatar
That relief there was for the fuel pump on V8 engines ,
Redneck Rydes is offline   Reply With Quote
Old 03-13-2022, 10:17 AM   #5
Gregski
Gregski's Avatar
ah, thank you for correcting me
Old 03-13-2022, 10:55 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Start at one end, make a relief cut about 1" in, angled toward the center of the radius, heat & hammer down first piece, another relief cut, heat & hammer down second section (trim sides as necessary), and continue down the line. After you are happy with the outcome weld up & grind down.
LockDoc
Leon
Old 03-13-2022, 01:54 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yup... will need to reroute fuel line to get past it if mashed flat.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-13-2022, 05:18 PM   #8
truckster
truckster's Avatar
Gary
It appears he's building an electric truck.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-13-2022, 05:46 PM   #9
CG
BlahBlahBlah
Link to his build ....
https://67-72chevytrucks.com/vboard/...d.php?t=826089
Old 03-13-2022, 10:59 AM   #10
Myself
I'd just heat the whole area red with a torch and hammer and dolley it flat. It won't really take that long to do.
Myself is offline   Reply With Quote
Old 03-13-2022, 11:10 AM   #11
LockDoc
LockDoc's Avatar
I tried that. You end up with wrinkles in it that you have to grind off and weld up anyway so it's just as easy to make the cuts and do it a section at a time, and it looks better overall when you are finished.
LockDoc
Leon
Old 03-13-2022, 11:41 AM   #12
CantPutTheSmokeBack
You could also cut that top section out, then weld in a new piece. Just be sure to get thick enough donor material. You could even cut that section out, flatten it, then cut off excess and weld it back in.
CantPutTheSmokeBack is offline   Reply With Quote
Old 03-13-2022, 12:18 PM   #13
SCOTI
SCOTI's Avatar
I've used a big crescent/pipe wrench to get it done. Start @ one end moving the lip down a little. Move over about the width of the tool jaws & repeat. Continue following the raised area. Repeat until it's flat & use a 60grit flap disc to true the edges w/the surrounding rail sections. A little hammer/dolley work helps as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-13-2022, 01:02 PM   #14
Gregski
Gregski's Avatar
funny you say that cause I just scored these large adjustable hammers on Craigslist, the big one is even made in the US.... Bonus!
Old 03-13-2022, 12:22 PM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Gregski did the square body find a new home.
Reading your thread was a good read.
Old 03-13-2022, 01:07 PM   #16
Gregski
Gregski's Avatar
yes, and thank you, a father and son duo came by ca$h in hand and took Rusty to a great new home, we stay in touch, they just sent it to the body shop and it's going to get painted, he is keeping a similar look of green n black but wants a rear bumper and to ditch the slider back window, I am glad he likes it
[shameless self promotion]
please check out my current build, the truck is called Dusty and I'm making it electric, I have some YouTube videos to go with it on my Good Enuff Garage channel
My Dusty 71 GMCe Electruck
[/promotion]
Old 03-14-2022, 02:05 PM   #17
GASoline71
GASoline71's Avatar
Nevermind then...
Gary
Old 03-17-2022, 10:33 PM   #18
Gregski
Gregski's Avatar
I love this forum, armed with your advice I put on my Big Boy Pants and made sum noise
Old 03-17-2022, 10:35 PM   #19
Gregski
Gregski's Avatar
first up, Big Bertha and sum brut force
Old 03-17-2022, 10:37 PM   #20
Gregski
Gregski's Avatar
then the mini death wheel
Old 03-17-2022, 10:40 PM   #21
Gregski
Gregski's Avatar
please don't knock these little Home Depot torches until you've tried a proper torch like this Benzomatic TS8000, cause it doesn't matter if its the blue bottle or the yellow one, it has nothing to do with the type of gas or fuel but everything to do with the proper mixture
Old 03-17-2022, 10:42 PM   #22
Gregski
Gregski's Avatar
she's gettin' there
Old 03-17-2022, 10:43 PM   #23
Gregski
Gregski's Avatar
not bad for an email administrator
Old 03-18-2022, 10:09 AM   #24
jaros44sr
jaros44sr's Avatar
Just like it never happened, nice work
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-18-2022, 02:03 PM   #25
Gregski
Gregski's Avatar
ha ha, thank you, now just to weld up the Swiss cheese frame rails
these must be them speed holes that went with the JEGS stickers on the quarter panels, good for at leas 20 hp
