Old 03-21-2022, 03:31 PM   #1
denverslim
Removing flat trim on bed?
I'm working on removing the flat stainless trim to peck out the dents in deformations from over the years in a tight garage. The cab and forward have nuts that I can access (although not easily) but there is no way to get to the back of the trim on the bed because of the inner sheet metal. How would I go about removing this stuff without stretching or damaging it?
Body man, I am not, however I can handle the dents in this SS.
Thank you all in advance.
denverslim is offline   Reply With Quote
Old 03-21-2022, 03:46 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Removing flat trim on bed?
I believe the trim uses clips on the bed sides.
It's a slight challenge, but you can get your hand between the inner and outer sheet metal. Definitely much easier with the bedside off to reach up in between.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-21-2022, 09:00 PM   #3
denverslim
You're exactly right. I just didn't look good enough.
Now I'll get out the band aids and go to work. Thank you.
Old 03-21-2022, 11:37 PM   #4
cwcarpenter98
Happy to help! If you're doing it by yourself, maybe hang the trim with a couple pieces of tape so it doesn't fall off after all the clips are popped out.
Christian Carpenter
