04-15-2022, 07:52 PM | #1 |
Correct valve cover decal?
I've searched a lot but can't find a definitive answer...
What's the correct valve cover decal for a 1972, Flint built Chevy C10 with a 350V8 ? Is it the Tonawanda? Something else? None? Help please.
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor |
04-15-2022, 08:17 PM | #2 |
Re: Correct valve cover decal?
The only standard valve cover sticker I am aware of for a 72 350 is the emissions cert. I've only seen Tonawanda stickers on big blocks, but that's just from memory, someone may have a small block with one.
04-15-2022, 08:20 PM | #3 | |
Hoping someone else can chime in...
04-16-2022, 01:24 AM | #4 |
i asked a question a while ago about the Tonawanda valve cover on a 72 big block truck but didn't get an answer.my truck didn't appear that it ever had one,a low mile original 1 owner truck,built in Fremont,Ca and a Tonawanda,NY
engine.i put a decal on but not sure if it's correct?my 67 impala wagon, with it's original Tonawanda 275 H.P 327 had a Tonawanda #1 team decal on the drivers side valve cover from new,also a low mile,1 owner car i've had since 1999 and i put a new one back on.i have seen a Flint built decal but as i recall,it was in the driver's door jamb lust like the GM of Canada decal i've seen in the door for Oshawa,Ontario built trucks. |
04-16-2022, 07:44 AM | #5 | |
After more endless searching it seems that the Tonawanda decals came on big blocks, and the 'aluminum foil' stamped Engine Emiisons Cert decal came on 3/4 ton and up trucks. So it would appear mine shouldn't have anything... It looks naked, but I am trying to keep her as original as possible.
04-16-2022, 12:25 PM | #6 |
In regards to the Tonawanda decal, it came on small blocks as well, at least in regards to the Camaro and other passenger cars, most common on high performance small blocks like the L79 and 302. There is also a similar decal that looks like the Tonawanda decal but its for the Flint engine plant. I know on 67 Camaro's the Flint decal was attached at the front end of the passenger side valve cover. On small blocks though the decal usage falls off really after 1968. In 69 on Z/28's and Corvettes they went to the finned valve covers and didnt seem to place the decals on them.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
