Equal opportunity joke ofender
![]() Join Date: Oct 2011
Brake hoses
Does anyone still make brake hoses that fit? I have ordered from Napa, Summit and Rock Auto and all 3 sent me the same rear hose that does not fit without having to modify it. All three were packaged different (napa, Dorman & Raybestos) But all are a sunsong cheap chinese crap. The center mounting bolt will not fit thru the mounting hole as shown in the pics.
EDIT: The original hose is 3/8" and all three new ones are 5/16". I have a message in to inline tube to get specs on theirs to see if any different than what I have here. .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. Last edited by richard2717; 04-22-2022 at 11:16 AM. |
Re: Brake hoses
That sucks. More & more typical.
Hope to see some responses with good info.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2020 Ram 2500, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. ![]() Members Met: Aldtime, DeadheadNM |
Re: Brake hoses
I got a message back from Inline tube that said they do not have the specs that I asked for. I would have to order them and return them if they were wrong. Really? I did have a member pm me with a lead on a nos Wagner hose that looked promising so I went ahead and ordered it. I am hoping it is correct and will post back with my findings and part numbers (I bought some wagner front hoses as well) if they are correct.
All the other hoses I have sourced have Sunsong printed on the hose and it has been my experience that they are bottom of the barrel chinese rubber that fail within a couple of years.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
![]() Join Date: May 2011
Re: Brake hoses
That looks like the end that is on my 2wd, another source if wagner doesn't work maybe GMCPauls
#5 | |
Re: Brake hoses
I am researching more today, I can't believe I am the only one having this issue
Re: Brake hoses
I just looked at GMCPaul's, it looks like the others you ordered!
Re: Brake hoses
Sorry I meant to say that I had already checked Pauls.
Any Idea if the 86 K5 blazers had metric or standard brake lines? The hose i found for that, the picture of the mounting block looks correct and is squared. Fitment says it does not fit the 72 which leads me to believe it may take metric fittings? here is a pic of the 86' hose .
Re: Brake hoses
I have ordered another and should be here Saturday. Brass ends and all like the original if the picture is to be believed. They have quite a few in stock so if it turns out to be correct I will follow up with part number & link to buy
Re: Brake hoses
A 3/8" reamer will get them to fit.
Re: Brake hoses
well my last attempt to get the correct hose is a no go. Hose looks identical but the ports in the brass block are 1 size too small for the brake line to screw in. If the fitting at the block was the same as the fitting at the wheel cylinder it would have been an almost perfect match. Tired of searching so will end up drilling out the wagner hose I bought and install it.
On a different note I did find oem brass end style front hoses and the seller still has 4 left if anyone is interested. https://www.ebay.com/itm/18425637379...53.m1438.l2649 .
