Brake Line fitting size?
72 manual disc/drum
what is the thread/pitch of the front & rear brake line fittings that goes to distribution block? |
![]() Join Date: Feb 2016
Re: Brake Line fitting size?
Please post a picture. Otherwise we are just guessing.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
The front & Rear brake line on proportioning valve (yellow arrow), what size are those line fittings?
Who Changed This?
![]() Join Date: Jan 2013
The one on the left of the pic is 3/16" tube, so should be a 3/8" nut. The other line is 1/4", which I believe has a 7/16" nut. Are you looking to buy line wrenches? I have some you can use. You're only a few miles from me.
I have flare wrenches......and this set that is the Snap On clone, only $200 less
Who Changed This?
I don't remember the thread pitch, but a b-nut is a b-nut. They only have one pitch. I think I have some in my parts stash. I'll take a look.
ETA- both have 24 pitch threads.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 05-08-2022 at 11:25 AM. |
I want to know the thread size to see if I need adapters for the new MC/Booster/PV I am installing
front 3/16-18?...or? rear 7/16-24? |
No one knows the thread size & pitch of the stock front & rear brake lines connection to proportioning valve??
Using the CPP disc/drum proportioning valve. In other swaps I have done on other cars I needed a few adapters to connect existing brake lines to aftermarket PV, was hoping to find out before swap so I have them. |
I just completed this job a couple days ago on my 1972 k20. I put a new proportional valve on and converted my rear drum to disc. However, the same fitting sized were used. I made about 5 trips to napa because I was trying to find the right fittings.
You will need 3/8-24 inverted flare nut (7/16th wrench) for the front brakes 9/16-18 inverted flare nut for the rear brakes 1/2-20 and 7/16-24 connection for the master cylinder Mine was all stock that I replaced. Hope this helps.
1972/Sierra Grande k2500 / 383 / th350 with Gear Vendors / 4.11 / 4" lift with 35s / Eaton Rear Axle |
![]() ![]() Join Date: Jan 2005
The CPP PVK installation instructions list the sizes of the ports on the CPP combination valve.
Thanks guys, I do have the 411 info in the CPP kit....are the stock lines the same size fitting as the CPP kit?
