![]() Join Date: Aug 2017
Air Compressor toggle switch
So I was thinking about setting up a switch to kick on my air ride compressor while still using a pressure switch. Kind of a bypass on/off to the pressure switch. Currently my compressor only kicks on at 165psi and shuts off at 200psi.
My thoughts is to wire this into a single speed wiper switch for a 1964-1966 C10, since it's just a open and closed circuit type switch. Plus no one would ever know as it would look completely stock. My questions are the following: Would the switch above be able to handle that kind of current? Any way to wire this up to where the pressure switch will still turn off the compressor once it's at pressure to avoid adding to much air to the tank? Just a brainstorm, so feel free to educate me. ![]() |
![]() ![]() Join Date: May 2015
Re: Air Compressor toggle switch
as far as turning it on and off, just use a relay with enough amp rating to run the compressor..
as for turning it off at pressure , id think you would have to run the power thru a pressure switch of sorts...im betting the compressor is sealed up with no way to tie into it you could use a simple pressure switch to accomplish that...maybe similar to this... https://www.amazon.com/Viair-90103-1...a-569509711579
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-09-2022 at 05:02 PM. |
#3 | |
Moderator
![]() ![]() Join Date: Aug 2011
Yep, I second the relay the switch idea.
