HELP truck dieing
I have a 1985 350 carburetor truck with duel tanks I have replaced the fuel pump - sending units- transfur valve - and all the hoses truck runs great and randomly dies I have a clear fuel filter and it is empty and will not start if it seats for a day or two it will start
Re: HELP truck dieing
Three things to check IMO it is easy to pinch the fuel lines above the tanks when re-installing them vented gas caps may be plugged may be sucking air into the lines somewhere causing no fuel to be pumped
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
If during the sender and hose replacement, you deleted the charcoal canister and plugged those lines, the tanks won't have a vent. The stock gas caps are not vented. Pre-canister tanks had a small plastic vent cap on a short piece of hose.
Mice will sometimes nibble holes in gas lines letting air into the system. Don't assume the new fuel pump is problem free. QA isn't what it used to be. |
yes the canister was all deleted the fuel pump has the feed line and the return line if I clamp off the return line it gets fuel to the filter and starts
Just here to tinker
Sounds like the tank can’t breathe and is pulling a vacuum.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
I have duel tanks, if I remember right years ago I popped a fuse and it killed the transfer switch. check that out. Been 20 years
Just a thought
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
What shape is the ignition system in? A failing distributor module could also have similar symptoms when the module heat soaks.
If you connect a Mity Vac to the fuel inlet line you can see how easy it is to pull fuel. If there is a pin hole you should hear it hissing. If fuel flows easily then your fuel pump is too weak
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
| Bookmarks |
