Truck Bed Tie Down Options?
72
Looking for a fold down tie down insert for bed side or D ring type that would use one of the truck bed bolts to anchor. ideas appreciated |
Re: Truck Bed Tie Down Options?
I drilled about 1/2" hole into the side of the rear stake pocket, enough to slip in a tie down hook.
there is already a large hole in the bottom of the front stake hole, good to attach tiedown hooks. |
Not a bad nut after all..
Bull Ring 4098 fits the rear two stake pocket locations in '67-'72.
I'm happy with mine. Only minor complaint is I can hear them rattle slightly when retracted when I have the sliding rear window open.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Did you try them in the centre and front holes as well. Listing on go to 88 model year on their website.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
They don't fit these locations on '67-'72 (opening is the same, but there isn't enough room below the opening to install).
^^, those are what I have as a placeholder...did see a C10 with D hooks on a 2 bolt strap mounted on inside of bed, top, where rail slots are that also looked discrete but require drilling holes. Have not found Stainless ones, just zinc coated
Maybe not what you need but I replaced four bed bolts with "I" bolts to serve as tie down points. Just in the front of the wheel wells. Then I had a cargo net that held down the cooler and lawn chairs.
See pic. |
^^^, considered that also but using single bolt D rings so they would lay flat
Like your bed, mine is "done" so I am not hauling anything other than coolers, boxed merchandise so a single bolt held something would work just need to find stainless vs "metal" (zinc) type |
![]() Join Date: Nov 2008
I posted the ones I used last year. Pictures are sideways but they work really well, I have had some serious load on them with no bed or anchor distortion. Not exactly a direct fit but not difficult to make work either.
https://67-72chevytrucks.com/vboard/...d.php?t=823196
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
