05-15-2022, 11:17 PM | #1 |
Will stock GM HEI work on an original Tachometer?
Has anyone had any experience hooking up a factory 67-72 tach dash to a totally stock GM HEI from the late 1970's/early 80's. thanks for the input.
05-15-2022, 11:44 PM | #2 |
Re: Will stock GM HEI work on an original Tachometer?
It does.
05-16-2022, 12:11 AM | #3 |
Works great on mine!
Smitty '71 Short Fleetside Spring Valley, Ca. |
05-16-2022, 07:40 AM | #4 |
The one on mine is not accurate. Have tried all the tricks mentioned to make them compatible, but the RPMs change and get off by over 1000 RPMs the higher you go in the RPM range. Works perfect on a non-HEI distributor, just not on the HEI.
05-16-2022, 10:22 AM | #5 |
Not on my truck but the OEM knee knocker tach works with the HEI on my Chevelle .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
05-16-2022, 10:53 PM | #6 |
I had similar experiences on my Burban.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-16-2022, 03:15 PM | #7 |
Works good on my stuff.
Saskatoon, Saskatchewan Canada |
05-17-2022, 12:58 AM | #8 |
05-17-2022, 03:27 AM | #9 |
Going the other way, my SunTach by AutoMeter works well. It's on a 292 L6 on a '68 C/10 Stepside shortbed in original 516 Orange.
Tach and coil work OK with stock Delco Remy HEI* parts. No interference. No signal-induced misfires. Play well together. Same tach worked well with points, too.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-18-2022 at 05:57 PM. |
05-18-2022, 05:32 PM | #10 |
As others mentioned... Mine reads slightly low at idle, and gets significantly farther off as RPM's increase.
There is someone making boards for these for half the price of a new one, but i've yet to pull out the tach and test the circuit components on the board to see if they're good. I'm hoping i get good news and find a resistor out of spec that can be changed for a couple bucks... but whose that lucky!? |
