![]() Join Date: May 2014
HEI distributor - where are the model numbers located?
Hey all, I've got an HEI distributor in my '67 6 cylinder pickup and wanting to order parts for it.
Does anyone know where they stamp the casting number/model number.? I'm wanting to buy a cap and internal parts and would like to know what year the distributor is from. Truck is a '67 but I'm guessing the HEI is from 70's.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
Re: HEI distributor - where are the model numbers located?
It's stamped on the side of the base. Just below where the cap sits.
Rick |
If it's at factory HEI casting model it 1975-86, since you have it in your 67 betting it a 75-80 year if it's factory casting model. You could have one of the factory 74 pre-version HEI conversion not as good. The guts deferrer for motor and option's of distributors. But 1975-86 HEI distributor casting case are all the same for your motor span.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
All I can offer is if you have an external coil 6cyl HEI, that came factory on a 1976 250cid Nova.
Moderator
![]() Join Date: Oct 2008
1974-77 will have the external coil seven post cap.
1978-on will have the coil in cap setup with six posts on the cap. The inline 6 specific parts are the body, advance, shaft, gear, cap, rotor, reluctor, and pickup coil. The in cap coil D221 condenser/pigtail is the same for the V8 & inline 6. The in-cap coils should be the same. The in cap coil ignition module should be the same.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
