Old 06-09-2022, 02:48 PM   #1
56 3100
56 3100's Avatar
bedwood rear edge ?
For those who have stock style bedwood.is the rear edges flush with top of rear sill or up above edge some like in my pic ?wood is 3/4" thick now. anyone with pics would be great! mine is like in the pics. do i need to plane it down more?
56 3100 is offline   Reply With Quote
Old 06-10-2022, 12:00 AM   #2
joedoh
joedoh's Avatar
Re: bedwood rear edge ?
looks like you havent tightened the bolts yet, try that and see what happens. your strips are really standing pround of the wood and they should be flush/slightly less than flush.
Old 06-10-2022, 01:58 AM   #3
fauXGT
fauXGT's Avatar
Yep. The carriage bolts still look loosey goosey.
When they get german (good'n'tight) the strips will drop into the channels into the planks and drop close to flush to the back at the tailgate.
The wood will give a bit.
Chip
'51 Chevy 3600 5 window
C4 Vette front/rear suspension & drive train
full Rusto-Mod
'92 GMC Sonoma GT VIN #0015
'91 GMC Sonoma GT extended cab 1 of 1
fauXGT is offline   Reply With Quote
Old 06-10-2022, 02:02 AM   #4
fauXGT
fauXGT's Avatar
Example
Chip
full Rusto-Mod
Old 06-10-2022, 06:54 AM   #5
56 3100
56 3100's Avatar
faux are your bolts tight in that example pic?
Old 06-10-2022, 09:19 AM   #6
Tempest67
Tempest67's Avatar
rather than plane down the entire board, you may consider just removing 1/16 of an inch from the underside where the cross brace is.
just a suggestion.
Tempest67 is offline   Reply With Quote
Old 06-10-2022, 12:22 PM   #7
fauXGT
fauXGT's Avatar
Fairly, but my boards are pine. Much softer so they will give a bit when clamped. Tempest has an idea, but you have to look at how the boards set flush under the angle side brackets. Taking material from the bottom of the boards will create a gap on the sides. If you don't like how tall the runners look, you could take a bit of material off in the wood runner channels. That way they sit lower but the boards are still snug under the side runners.
Chip
full Rusto-Mod
