06-09-2022, 08:56 PM | #1 |
SRW K30 and K20 differences
I am trying to figure if K20 and 30 shared the same frames, rear ends, and springs in the rear. I am guessing up front the difference was K30 got a Dana 60 and K20 a 44? Were the front springs different as well? Any other differences? Thanks,
Marvin Posted via Mobile Device |
06-09-2022, 10:41 PM | #2 |
Re: SRW K30 and K20 differences
On the K30 rearend the shocks were moved to the inside of the frame, the drivers side was forward of the axle, and the springs were on 40.5” centerline instead of 42”
06-09-2022, 10:59 PM | #3 |
06-09-2022, 11:07 PM | #4 |
06-10-2022, 07:29 AM | #5 |
Active Member
K30 frame is taller than a K20. Front springs mount the same, rear springs have different front and rear mounts, springs themselves MAY be different, some K20 came with 52" springs, others with 56" springs - K30 rear springs are 56"
06-10-2022, 12:35 PM | #6 |
K20 generally had SF and the K30 had FF. I have a K30 in my K20. Had to relocate spring perches and shock mounts.
06-10-2022, 03:37 PM | #7 | |
K30 frames are 8" tall behind the cab vs 6" tall on a K20 K30 rear shocks are located inside the frame vs. outside the frame on a K20 Lots of rear spring info in these info packets outlining the different spring packs between the two; https://www.gmheritagecenter.com/doc...olet-Truck.pdf
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-10-2022, 04:36 PM | #8 | |
