06-12-2022, 10:09 PM | #1 |
64-66 Radiator
Hello all, wondering if anyone makes a cross flow radiator for the 64-66 trucks,
I'm planning to put a big block in my truck and a cross flow radiator is better cooling than a down flow radiator. So in my searches for a radiator I am not finding anything to convert a down flow to a cross flow for these trucks, Has anyone done this conversion? What did you use? Or Am I just stuck with a down flow from one of the many suppliers? Thanks in advance |
06-13-2022, 11:12 AM | #2 |
Moderator
Re: 64-66 Radiator
I know US Radiator makes a triple flow for our trucks. Haven't eyed a cross flow myself. Someone else may have though.
06-13-2022, 12:17 PM | #3 |
It's Better With Nitro
Re: 64-66 Radiator
You can talk with Griffin Radiator about building one to fit the dimensions you want. I just had them build a radiator for an older AC Cobra replica kit car that I'm helping a customer get running again with an odd core size to fit that sloping nose and it was crossflow.
I run a downflow radiator (aluminum dual 1.25 tubes) in my C10 462 ci.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
06-15-2022, 08:12 PM | #4 |
Re: 64-66 Radiator
That looks like a nice option but they are very proud of it
06-15-2022, 08:47 PM | #5 |
Re: 64-66 Radiator
found this vendor and looks like a good option but it is not a cross flow
https://www.coldcaseradiators.com/pr...mance-radiator Too bad that is seems no one is making anything that is a cross flow drop in for our trucks Last edited by 65Custom; 06-15-2022 at 09:24 PM. |
06-15-2022, 08:00 PM | #6 |
Re: 64-66 Radiator
RnD fabrication is a vendor here
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-17-2022, 11:57 AM | #7 |
Re: 64-66 Radiator
Check reviews before ordering...
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
06-16-2022, 09:07 AM | #8 |
Re: 64-66 Radiator
My 427 BBC runs cool with a standard design vertical flow radiator and an electric fan. Champion sells several different radiators for different power ratings.
06-16-2022, 08:42 PM | #9 | |
Re: 64-66 Radiator
Thanks for the response, guessing I will be going with a down flow which will be a more original looking under the hood and and less aggravation installing it as well. |
06-17-2022, 09:40 AM | #10 |
Re: 64-66 Radiator
My brother runs a Griffin cross flow (27.5" x 19") and dual fans with his built 468 Big block and it has been good. I, on the other hand, tried the Griffin and it came apart after 2 years so I went back with the Speedway 28" x 19" crossflow and a 18" T-bird/Cougar fan.
06-17-2022, 05:15 PM | #11 | |
Re: 64-66 Radiator
06-17-2022, 05:33 PM | #12 |
Re: 64-66 Radiator
You'll have to change the mounts for a cross flow, but if you can find one that fits in the available space, it would probably work
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
