Old 06-20-2022, 12:25 PM   #1
Gregski
Gregski's Avatar
Did the 1/2 ton short beds come with a two piece driveshaft?
I am just wondering if the 1/2 ton C10s with short beds ever came with two piece driveshafts, or will I be looking for a Unicorn?
Gregski is offline   Reply With Quote
Old 06-20-2022, 12:32 PM   #2
mkmc69
mkmc69's Avatar
Re: Did the 1/2 ton short beds come with a two piece driveshaft?
Yes. I had a 67 step side that had one and my 70 that I have now. So not quite a unicorn.
mkmc69 is offline   Reply With Quote
Old 06-20-2022, 01:43 PM   #3
67C10Step
67C10Step's Avatar
My 67 short bed is a two piece as well. My 70 model years ago was a one piece. If I ever swap to an automatic transmission I may go back with a one piece.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-20-2022, 04:24 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
My 71 had a 2 piece. Original 250 6cyl with 3 OTT.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-20-2022, 07:03 PM   #5
Smitty
Smitty's Avatar
My '71 short Fleet side with the 307 and 3ott had a 2 piece. But when I went 350 with the 700 I went to the one piece.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 06-21-2022, 01:45 AM   #6
Gregski
Gregski's Avatar
thank you all so much for your feedback I picked up a long bed two piece driveshaft today after learning that they all are the same length from the center bearing support to the rear axle, that will work for me as I am mating it with a Lexus GS450h transmission so I will need to have the front cut and a three bolt flange welded on anyway
got this from a super nice guy named Chris is Westley California for $150 (ish) bucks, the price went down the more things I put in my little to buy pile, ha ha
Old 06-21-2022, 01:47 AM   #7
Gregski
Gregski's Avatar
I also learned how there are two types of drive shafts a skinny one (the size of your wrist) with a flimsly center support bracket and a heftier one with a stronger middle bracket like this one (I got this off of a 3/4 ton long bed) also from Chris in Westley California for $80 (ish) bucks (price adjusted the more suffs I bought) Chris is a great guy
Old 06-21-2022, 01:50 AM   #8
Gregski
Gregski's Avatar
I don't mean to brag but I am a bit of a third degree rust belt Ninja with the wire wheel
Old 06-21-2022, 09:42 AM   #9
Keith Seymore
Keith Seymore's Avatar
Ha! I am an artiste with a die grinder.
We could make beautiful music together.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 06-21-2022, 01:52 AM   #10
Gregski
Gregski's Avatar
and 17 minutes later...
Old 06-21-2022, 01:55 AM   #11
Gregski
Gregski's Avatar
let's not forget the doo dad, bird poop and all
Old 06-21-2022, 01:56 AM   #12
Gregski
Gregski's Avatar
now it's ready for the media blasting cabinet and later DIY powder coating
Old 06-21-2022, 02:05 AM   #13
Accelo
Accelo's Avatar
My 70 SHORT Box had a 2 piece. Original 250 6cyl with 3 on the tree.
Accelo is offline   Reply With Quote
Old 06-21-2022, 09:07 AM   #14
Wore those bristles down a bit, did ya? Looks great.
I'd like to ask anyone giving 2pc SWB driveshaft info to include the engine and transmission the truck came with. I'm unclear on the rhyme and reason for 1pc vs 2pc driveshafts. It looks like 6cyl/3spd SWBs came with 2pc
Old 06-21-2022, 09:19 AM   #15
Gregski
Gregski's Avatar
I hear ya, here's an actual photo of the General's process for determining which truck gets which driveshaft:
hope this helps,
Old 06-21-2022, 09:35 AM   #16
Keith Seymore
hope this helps,
I've been expecting this post.
My response:
It has to do with propshaft (aka "driveshaft") critical speed.
Propshaft critical speed not just based on wheelbase but is also based on trans type (length), rear axle ratio, tire size, and engine type (larger engines allowing a higher top speed) AND/OR any strange resonances in that particular combination (camping out on that resonance will break the trans/transfer case tailshaft housing).
So - a long wheelbase truck with a low (numerical) rear axle ratio spins the shaft slower and might get a one piece, but an otherwise comparable truck with a high rear axle ratio might get a two piece.
One other comment - critical speed is not directly related to balance, but rigidity. When the shaft exceeds it's critical speed it begins to bow in the middle and swing like a jump rope. Hence the disturbance and durability concerns.
You can get around it by going to a larger diameter steel tube - or more expensive alternative materials like aluminum, carbon fiber, an aluminum/carbon wrap, or exotic materials like "metal matrix" (aluminum impregnated with other metals).
So - given two otherwise identical appearing trucks - there could be a tire difference that put it over the edge, or perhaps a different horsepower rating which would allow for a higher top speed, or some unseen bending resonance that shows itself during testing.
K
So - not only could we manipulate one pc vs two pc based on material selection, but the program team might even speed limit a vehicle (via pulling fuel or ignition) to limit top speed to allow a one piece configuration.
K
1979-1986
1986 - 2019
Old 06-21-2022, 09:44 AM   #17
mr.mud1
mr.mud1's Avatar
My response:
K
thank you sir,wonderful information that makes perfect sense once you explain it.
mr.mud1 is offline   Reply With Quote
Old 06-21-2022, 01:09 PM   #18
Bob B.
My response:
K
As an example, my employer bought a large number of mid-2000's Silverado 4X2 2500HD's with 6.0L/4L80E powertrains. One year they all had fixed yoke transmissions with 2 piece steel driveshafts and a center support bearing. Next year they had slip-yoke transmission output shaft with a large diameter one piece aluminum driveshaft. I believe the trucks were spec'ed identically, in fact they may have been a continuation of the same order.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 06-21-2022, 09:41 AM   #19
Keith Seymore
Tim - if you EVER have any questions on any of this engineering stuff I am happy to answer them for you.
K
1979-1986
1986 - 2019
Old 06-21-2022, 09:45 AM   #20
Gregski
Gregski's Avatar
K
Folks, Mr. Keith Seymore is a treasure trove of valuable information, he has helped me many a times with my '74 squarebody build, we must cherish him at all costs (and perhaps clone him) thank you sir!
Old 06-22-2022, 08:11 AM   #21
K
Keith that's an awesome offer. I wish I had a list made up already
Old 06-22-2022, 05:50 PM   #22
Mike C
Mike C's Avatar
There is at least one more carrier bearing as well, the “Heavy Duty” which is in the triangular shaped clamshell. That’s what is on my ‘69 short step which is 307/TH350 powered and 3.07 gears. Obviously a two piece since it has the carrier bearing.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-23-2022, 01:13 AM   #23
Gregski
Gregski's Avatar
thanks, would you have a pic to share with us please and thank you
Old 06-24-2022, 08:57 AM   #24
Keith Seymore
I also do "abandoned factory" driving tours in Detroit and the surrounding burbs, if you are ever in the area.
K
1979-1986
1986 - 2019
Old 06-21-2022, 11:18 AM   #25
pjmoreland
pjmoreland's Avatar
I owned a 67 shortbed that came from the factory with a one-piece driveshaft. It had a 250 engine, a 3OTT transmission and an overdrive unit. It also had 4.10 gears. The gears and overdrive were listed on the SPID. There was no center support bracket on the crossmember.
pjmoreland is online now   Reply With Quote
