Old 06-28-2022, 02:45 AM   #1
ibrown50
ibrown50's Avatar
Static dropped 64 - Alignment Specs
Hello,
I’m almost finished the build on my ‘64 and it’s time to get the alignment done. It’s dropped 4” at the front (-2” spindles and -2” spring) and 5” at the rear ( 4” spring and 1” lowering block). Could anyone help me out with the camber, castor and toe-in specs. I’m in England so it’s unlikely my alignment shop will have them
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 06-28-2022, 07:53 AM   #2
Paul Y
Re: Static dropped 64 - Alignment Specs
A timely post Ian as I am approaching that stage.
Do we have another series of pictures incoming?
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 06-28-2022, 08:15 AM   #3
SCOTI
SCOTI's Avatar
A good read....
http://67-72chevytrucks.com/vboard/s...lignment+specs
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-28-2022, 10:28 AM   #4
SkinnyG
SkinnyG's Avatar
If it's just a street vehicle, I'd do as much positive caster as you can adjust into it, about -1/2° to -1° camber (more negative if you want to drive hard), and about 1/16" toe in.
Your shop will likely want degrees for toe. Maths.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
