Old 07-03-2022, 02:47 PM   #1
schovil69
Detent Cable
I'm struggling to locate a new detent cable with the proper mounting attachment on the cable. This photo is prior to cleaning/painting/installing on the engine and you can see the mounting bolt just in line with the edge of the wood where the detent cable attaches.
Is there a manufacturer of the TH350 detent cable where the attachment on the mounting bracket is a bolt and not the square push through type?
schovil69 is offline   Reply With Quote
Old 07-04-2022, 05:25 PM   #2
MikeB
MikeB's Avatar
Re: Detent Cable
FWIW, here's what LMC shows:
https://www.lmctruck.com/1967-72-che...-detent-cables
Can't remember what kind of bracket my 69 had from the factory, but it now has one like LMC's. I can't find one that looks like it would fit your bracket. If you have the old cable, please post a photo of it.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-05-2022, 09:53 AM   #3
HO455
HO455's Avatar
Re: Detent Cable
I don't believe there are different cables. But there are literally dozens of different brackets that GM used on the different carburetor configurations offered by the different brands.
It's possible yours may be missing a piece or has been modified.
Is your truck a V8 or I6?
A 2 or 4 barrel carburetor?
This thread may help.
https://67-72chevytrucks.com/vboard/...d.php?t=807083
RIP Bob Parks.
Old 07-05-2022, 10:53 AM   #4
RustyPile
RustyPile's Avatar
Re: Detent Cable
When I bought my truck, the detent cable was missing. It had a plug shoved into the entry hole on the transmission.. It also had a bent up dipstick tube and no dipstick.. I bought everything from a local transmission shop.
RustyPile is offline   Reply With Quote
Old 07-05-2022, 11:12 AM   #5
Accelo
Accelo's Avatar
Re: Detent Cable
The 1969 and 1970 Cables and cable retainers are different than the 1971-up ones.
Best I can tell, from your picture, you have the early bracket. The cables and brackets do not interchange. I'll see if I can find my examples and post pictures later.
If you have the later cable it will not attach to the earlier bracket. Much easier to find the later bracket than find the earlier cable.
The LMC bracket MikeB posted in the later style bracket.
Accelo is offline   Reply With Quote
Old 07-05-2022, 04:10 PM   #6
MikeB
MikeB's Avatar
Re: Detent Cable
Check out "CABLE ASSY, Detent Control" part numbers about 2/3 down the page below. Maybe you can determine which one fits your bracket and find a replacement somewhere.
http://www.gmpartswiki.com/getpage?pageid=22263
Mike
Old 07-05-2022, 06:19 PM   #7
schovil69
Re: Detent Cable
Thanks, not much popping up. There must be something undesirable with the design for there to be zero reproductions. Quite interesting that page refers to TV cables...
Old 07-05-2022, 12:45 PM   #8
schovil69
Re: Detent Cable
Thanks for confirming what I've found, so far. The bracket shown is an option still on the table but I would truly like to keep this vehicle nearly as stock as possible. I say it this way because I have no intention on restoring some items, such as the TSC.
I will get a photo of the detent cable end that mounts with my bracket the next chance I get.
Edit: Just found a photo from another thread that shows how the detent cable mounts to my bracket. This isn't from the pickup I'm working on but shows the mount with the bolt under the tape end.
Old 07-05-2022, 05:35 PM   #9
Accelo
Accelo's Avatar
Re: Detent Cable
I have an good used cable for the early 350 THm.
They are not in demand. LOL
Let me put an eye on it first but if you want it $10 + the ride.
PM if interested.
Cheers.
Old 07-05-2022, 06:20 PM   #10
schovil69
Re: Detent Cable
PM if interested.
Cheers.
PM Sent
Old 07-06-2022, 01:16 AM   #11
Accelo
Accelo's Avatar
Re: Detent Cable
With the new design (if you call 1971 new) their is little demand for the old cable.
The updated design is easier to adjust, no tools needed.
It fits with the faster install mandate on every assemble line.
The THM was made from 1969 to 1982 a 13 year run.
With less than 15% of the total production using the old design their is little incentive to repop the early cable.
However, because of it's simple design it may be out there somewhere.
With a simple upper bracket change it can be changed to the newer style cable.
Or in the case of the 350THM you could even run without the detent cable.
It's not possible to run without the TV cable installed on the 700R4-4L60's.
They preform different functions.
Cheers.
