Old 07-30-2022, 12:00 AM   #1
kingsthunder
Wrapped truck
Anyone try wrapping a 67-72. Any pics? Pros? Cons?
kingsthunder is offline   Reply With Quote
Old 07-30-2022, 07:06 AM   #2
Re: Wrapped truck
I can only think of cons. I was just looking at an electrical contractor's van wrap job this week and noticed how poorly a wrap job holds up. Paint is a good idea. My friend has a sign shop. He started out as a sign painter, meaning all hand work using paint. He does murals, lettering, pinstripe, anything, and now all the vinyl sign work. He does digital wraps, then enhances with airbrush work or hand lettering. He clears all his wrap jobs under to make them last. There you are back at shooting a spray gun at your vehicle. Might as well leave out the vinyl and just use paint
Old 07-30-2022, 08:41 AM   #3
KW5413
KW5413's Avatar
Re: Wrapped truck
As a side bar to ''clearing'' wraps...Some Trans Am owners around here cleared over the vinyl "Bird" on the hood. Those that lived in the Texas heat saw cracking / wrinkle effect. This was attributed to opposing substrate (vinyl vs clear) movement caused by the heat. This phenomena probably doesn't rear its ugly head in your region.
Speaking of heat...my garage is running 104F - 108F in this exceptionally high Texas heat.
KW5413 is offline   Reply With Quote
Old 07-30-2022, 07:11 AM   #4
Re: Wrapped truck
Biggest issue most folks do not take into account is the body has to be perfect or it will show thru the wrap. Cheap looking wraps normally are because of poor body underneath. Wraps are not really meant for long term. I believe a local wrap guy says the life spam is planned at around 3-5 years. Can they be done on our year trucks, yes. I have seen a couple and they did look good. Owners all said it was temporary till they had time to get a good paint job doen.
Old 07-30-2022, 08:27 AM   #5
KW5413
KW5413's Avatar
Re: Wrapped truck
The A # 1 thing to know about wraps is don't go cheap. Use a very good shop using the best wrap material. There are a couple beyond 3M but that's about it.
Most paint / body flaws will be mirrored in the wrap. So, paint correction is highly recommended.
It's difficult to really nail down the shelf life of wraps as it is highly dependent on the environment it lives in. In 2009 we wrapped my daughter's drill team enclosed 24' trailer. The succeeding teams never washed it and it was in the Texas sun. While it showed signs of oxidation...as would paint...it never lost adhesion. The wrap was finally replaced in 2019. The band wrapped their trailer around the same time but took care of it. I believe that wrap still lives.
I was going to wrap my '78 Trans Am but, got a friends & family price for paint & painted my Nova at the same time.
All the ''white'' on My '69 C10 is 3M wrap except the cab roof. It was on it when I bought it but I think it is at least 5 years old. The truck is garaged.
