08-09-2022, 07:30 PM | #1 |
Outboard shock mounts - 6.5"-7" Rear drop
Dad and I are changing my truck over to an outboard rear shock mount. My truck is pretty low, and I wanted to run a rear bar, so the original shock mounts had to move.
I got the idea from the No Limit setup. - do you guys think this will work OK?
08-10-2022, 08:14 AM | #2 | |
Re: Outboard shock mounts - 6.5"-7" Rear drop
Not saying it would be an issue but it's possible vs positioning a single shock stud @ the back side that allows the lower shock bushing to pivot vs bind.
08-10-2022, 08:24 AM | #3 |
You're absolutely right..
Like this you're saying? So that way the rear axle housing has the ability to shift laterally as necessary
08-10-2022, 01:27 PM | #4 |
Correct.
08-10-2022, 11:49 AM | #5 |
67-72 parts collector,…
I like this kit from Tinworks Fabrication.
Great quality built products and fast shipping. It keeps both shock eyes on the same plane. Similar to the NoLimit kit. https://tinworksfabrication.com/prod...tion-brackets/
08-10-2022, 01:25 PM | #6 | |
Coil/Bag/truck arm/4-bar set-ups w/o a Watts Link to locate the housing will have side to side shift. While slight, it's still enough to create bind. I don't understand why they don't just re-clock the mounting points so the shock can pivot slightly side to side.
08-10-2022, 04:39 PM | #7 |
So could make new lower mount like the top mount and then turn the bottom of the shock 90 degrees? Then it wouldn't bind if the rear end shifted a bit.
08-10-2022, 07:32 PM | #8 |
A simple shock stud like used on the front upper would work or whatever dbl shear set-up for additional strength as long as the lower end can pivot w/o much bind side to side.
08-11-2022, 10:27 AM | #9 | |
I am assuming that lolife99 is planning on installing an adjustable long track bar and a rear sway bar. Both those items will reduce the amount of bind from the lower shocks mounts as they will actively reduce how much the axle articulates. In suspension design every component's placement is a compromise between what helps, what hinders, and what is feasible under the design limitations.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-11-2022, 01:02 PM | #10 | |
I always do the long track bar to the passenger side trailing arm and standard shock relocator. Tinworks Fabrication is a great company that is developing a ton of new products for GM trucks of several generations.
04-11-2023, 09:11 PM | #11 |
Where did you get those upper shock mounts, or did you fab them yourself?
04-12-2023, 11:48 AM | #12 |
The upper mounts are Ridetech. I got them from Summit. I think they were $20 or $25 each. They worked nicely. I'm going to give it a shot this way and just see how it goes. If it's binding in any way I'll rethink it.
04-12-2023, 12:55 PM | #13 |
I don't think the 'bind' (if any/much) will be an issue for you as long as when it's at the normal/average height w/full weight the set-up is bind free.
04-13-2023, 02:38 PM | #14 |
Are those a 2 pc mount? Can't seem to find a pic on the Summit site that looks like your photo unless it's a 2 pc mount like the photo below.
04-13-2023, 04:18 PM | #15 |
New Member
To me, it seems like lots of shock angle with that Tinworks setup.Not what we want is it?
04-13-2023, 04:40 PM | #16 |
I thought the same. My assumption/guess w/o measuring it is the location was being dictated by the need for clearance vs. the bed/bed floor support/s location on the frame.
04-17-2023, 07:32 PM | #17 |
I ended up doing something similar using a set of modified Summit rear shock locating brackets. I only have a 4" drop but my rear shocks were at about a 30
degree angle. Just have to get everything painted up and pretty yet. |
04-18-2023, 01:41 AM | #18 |
Kind of do not understand the thinking here. With a panhard bar the lateral (side to side) movement will be minimal. Especially with a longer panhard that is more parallel at ride height. Obviously, not a lot of articulation to worry about with the lowered suspension as suspension travel is limited. The change in shock angle even with standing them up more (as stock) will put more stress on the bushings more than lateral movement ever could. That is the reason GM put both of the shock mount bolts perpendicular to the frame. Put my rear shock mounts that way with 16" of wheel travel with leaf springs which will move side to side much more than a panhard setup. I will be able to bottom one rear wheel and have the other at full droop. Granted my shock eyes are a bit different with pivots in the ends. My case is extreme, I still hope I am getting the information stated correctly.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-18-2023, 10:29 AM | #19 | |
Is it possible? Sure. Is it a legit/correct statement across the board? Not w/o measuring. Even w/measuring, the parameters would have to be determined before the info is applicable (stock leaf vs stock T/A; dropped vs dropped). We know the T/A w/Panhard bar allows slight side shift by design. The shorter the bar, the more the shift. So if one is changing the stock shock location/positioning, it's not a bad idea to be aware. Monitoring for unusual wear & tear @ the shock mount bushings (oil change/maint intervals?) until they feel comfortable things are fine.
04-19-2023, 02:40 AM | #20 | |
04-18-2023, 02:42 PM | #21 |
I completely agree it is a little questionable how it will function, so I guess we'll see. This truck won't see a lot of daily driving, so I'm not real worried about it to be honest.
I have tubular trailing arms and QA1 rear bar, rear links, double adjustable hiem track bar, 315s etc. I'm not concerned about hauling stuff, pulling a camper etc. This truck will be for AutoX and / or spirited driving. I want it to be a touch more laterally stable than vertical anyway.. forward bite being important too, of course. But I guess we'll see what happens. If it's not what I'm thinking it will be I will bag it or change over to coilovers. It is what it is.. (for now)
04-18-2023, 04:00 PM | #22 |
Took the truck for a ride today to see how the changes affected the ride and handling.
The body roll is much improved with the front sway bar added and I think moving the rear shocks to outside the frame rails and behind the Diff also helps with the body roll. Before my rear shocks were at around 35 degrees tilted forward with the 4 drop springs. Also, there was significant tire hop during hard acceleration. Now with them vertical to the travel of the rear diff travel there is ZERO tire hop but the ride is also firmer, not too bad for a truck but definitely not as mushy as it was. |
04-18-2023, 04:23 PM | #23 | |
Sounds like you're happy so far.
04-18-2023, 05:42 PM | #24 | |
Next is to replace the rear trailing arms with some Summit tubular arms. Mine are twisted a bit and have a few holes rusted thru in them. |
