08-10-2022, 09:20 PM | #1 |
Seat belt mounting?
I'm getting ready to install a seat out of a 88-94 in my 67. I still have the tank in the cab. I see several people mounting the 88 and up style seat belts in. How are these being mounted ?. Are the floors being drilled and reinforced?
08-13-2022, 07:59 AM | #2 |
Re: Seat belt mounting?
On the passenger side you can use the factory mounts, driver's side you'll need to drill a new hole slightly forward of the factory hole and brace it. I made a plate of 1/8" steel and bolted it to the factory seatbelt hole, then drilled the new mounting hole. I don't have a lot of pictures from it way back when (2002/2003). I did not try this with factory seat, I used the seat from a 92 regular cab, which is where I got the belts from. The belts from the extended cab work better, as I found out later, as the housings are thinner. Middle belts work fine in stock holes although with stock seat you may need to use a longer grade 8 bolt and about a 1" spacer.
With the tank out they fit much better and use stock holes.
08-17-2022, 07:27 PM | #3 |
So I'm not sure if the retractors I have are different or something but with the mounting tab on the side I don't see how they could be mounted with the original holes..
08-17-2022, 08:50 PM | #4 |
Yeah those were likely first set I did. The blue ones. They will work but with the tank you'll need to move them forward of the factory outside mount holes.
08-18-2022, 05:51 AM | #5 |
Ok that's makes sense will have to try that after work.
Tags |
1967, 3 point belts, 88-98 seat belts |
