Old 08-18-2022, 12:51 PM   #1
cericd
cericd's Avatar
Looking for Original Acorn Cap Nuts from Factory Round Mirrors
I'm looking for a few original acorn cap nuts which were used to attach the original 67-70 round side view mirror heads. I have my originals but they have been painted over so I'm looking for nice originals that are still the original clear zinc finish, also, not rusted or all nicked up by adjustable wrenches.
All of the nuts I've found online are smooth round (no crown) or high crown which is why I'm looking for originals.
The nuts are 7/16" with 1/4"-28 (fine) threads. Here's a pic of my original (painted gold) nut and a pic I found online to show one in the condition I'm looking for.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 08-18-2022, 02:04 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Looking for Original Acorn Cap Nuts from Factory Round Mirrors
ive seen these at ace/truevalue hardware stores
1967custom
michael bustamante is offline   Reply With Quote
Old 08-18-2022, 03:50 PM   #3
cericd
cericd's Avatar
Thanks. I'll check there too.
Still like to find some originals.
Chris
Old 08-18-2022, 10:07 PM   #4
Grumpy old man
Grumpy old man's Avatar
This might help .
https://www.mcmaster.com/acorn-nuts/thread-size~1-4-28/
Old 08-18-2022, 11:38 PM   #5
cericd
cericd's Avatar
Originally Posted by Grumpy old man View Post
Thanks Grumpy. Those look interesting. I checked Fastenal and Grainger but forgot about McMaster Carr.
Chris
Old 08-20-2022, 08:37 AM   #6
jaros44sr
jaros44sr's Avatar
I've got a box of mirror stuff, do you want me to go through it, should be some nuts in there
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 08-20-2022, 02:20 PM   #7
cericd
cericd's Avatar
Sure, if you've got some nice originals I'd be interested in them. Mine are nice (no dinged edges) but I'm trying to find unpainted ones. Thanks!
Chris
Old 08-21-2022, 09:28 AM   #8
jaros44sr
jaros44sr's Avatar
Ok let me look, and see what I find
SAFETY FIRST
AS usual, off topic
Jim
Old 08-24-2022, 09:03 PM   #9
cericd
cericd's Avatar
Bump, still looking for these.
Chris
Old 08-26-2022, 10:56 AM   #10
ThreeQuarter
ThreeQuarter's Avatar
I found these a few weeks ago at Menard’s.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 08-26-2022, 11:11 AM   #11
ThreeQuarter
Side profile. Is this the crown you’re looking for, or is this what’s you’re calling smooth?
Ben
Old 08-26-2022, 11:21 AM   #12
cericd
cericd's Avatar
That’s what the websites I ran across were referring to as “smooth”. I’m looking for ones with an identical profile to my originals. They seem to be most often called “low crown”. There are also “high crown” versions with a taller, pointier head. Also, hoping to find them with less of a polished look.
Chris
Old 08-26-2022, 11:31 AM   #13
Accelo
Accelo's Avatar
I likely threw my originals out with the used up mirrors.
I understand you want identical.
Will need some measurement. Like total height and depth of the hex and the hex size.
If you find too shinny it's easy to dull them down in a shaker or tumbler for shells.
I could make you a couple but the finish would be raw steel. Not ideal.
Cheers
From the mcmaster.com site.
Accelo is offline   Reply With Quote
Old 08-27-2023, 01:02 AM   #14
cericd
cericd's Avatar
Bump
Still looking for some nice original, unpainted side mirror acorn nuts.
Chris
Old 08-31-2023, 05:35 PM   #15
cericd
cericd's Avatar
Found some.
1. Off a NOS 3960511 mirror (assume it's correct)
2. Modern Replacement (slightly shorter than other two but has acorn shape instead of smooth rounded top. Shoulder height looks the same as the painted one. I'd imagine GM had multiple sources for this nut over the lifecycle of these trucks)
3. Off my truck (assume it's original but painted)
Chris
