Old 08-20-2022, 11:05 AM   #1
Alloyvert
Active Member
Wheel ID
I finally located a matching wheel for my '64 and replaced this oddball that was on the truck when I bought it. Curious of the year and model??
Alloyvert is online now   Reply With Quote
Old 08-20-2022, 12:17 PM   #2
oem4me
Re: Wheel ID
I could be wrong, but if that wheel is 17.5" its is very hard to find. The eight lug version of that wheel was standard equip for C20's in the 60's and used to be fairly common. That is not at all the case with the half ton version, hence they are highly sought after especially amongst the 4WD crowd.
Old 08-20-2022, 01:20 PM   #3
michael bustamante
michael bustamante's Avatar
Re: Wheel ID
with is the tire size and the width?
15 or 16 inch? and bead to bead is it 5"?
1967custom
michael bustamante is offline   Reply With Quote
Old 08-20-2022, 02:49 PM   #4
Lokin4AReason
Lokin4AReason's Avatar
Re: Wheel ID
Is there any stampings on it like around the valve stem ?
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 08-20-2022, 08:37 PM   #5
Alloyvert
Active Member
Re: Wheel ID
It is 15x5.5 and not finding any stampings aside from the inner rim with “made in the USA 15 x 5 1/2 K NT 1 6”
Old 08-21-2022, 12:21 PM   #6
60-66
60-66's Avatar
Re: Wheel ID
Its a 1960 rim if it has the bumps on the outer edge of rim , or a 1961 possibly if no bumps .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 08-21-2022, 10:55 PM   #7
paulspickupparts
Re: Wheel ID
Also used on GMC of the same era including 59
paulspickupparts is offline   Reply With Quote
