Old 09-13-2022, 06:26 PM   #1
Classic Bowties
Always on the hunt...
F/S GM NOS & New Repro Steering Column Replacement Parts
We just pulled out some replacement steering column parts for another member and have the pictured extras sitting bench top ready to ship. We can send any of the below listed #1 thru #8 small parts in the CONUS for $8. via USPS small package and will offer combined shipment on multiple purchases here in thread or with any of our other parts listings, we can also ship parts out using the USPS priority flat rate boxes in case you want to add or request any other needed column parts not pictured. If interested, online funds can be sent via Zelle and CashApp, Credit Card over the phone or Check/Money Order by mail. Thanks, Mel
#1 } NOS upper column bearing for non-tilt. $60. ***Qty. 4 Sold/Shipped*** Have more on hand/available...
#2 } NOS lower column bearing for tilt or non-tilt. $75. ***Qty. 6 Sold/Shipped*** Have more on hand/available...
#3 } NOS horn contact t/s cancel cam for non-tilt. $30. ***Qty. 2 Sold/Shipped*** Have more on hand/available...
#4 } NORS horn contact pin, spring & retainer kit. $20. ***Qty. 5 Sold/Shipped*** Have more on hand/available...
#5 } Repro horn contact t/s cancel cam for non-tilt. $15. ***Qty. 3 Sold/Shipped*** Have more on hand/available...
#6 } Repro horn contact pin, spring & retainer kit. $8. ***Qty. 3 Sold/Shipped*** Have more on hand/available...
#7 } NOS shift indicator fiber optic cable bulb socket for non-tilt. $35. ***Part & pics added 09/15/24 in post #49***
#8 } OE used shift indicator fiber optic cable bulb socket for non-tilt, tested w/bulb. $18. ***Part & pics added 09/15/24 in post #49***
#9 } OE used inner main steering shaft from a 72 non-tilt steering column. $65. ***Part & pics added 11/04/24 in post #51***
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 09-14-2022, 05:45 AM   #2
jmader
jmader's Avatar
Re: F/S GM NOS & New Repro Steering Column Replacement Parts
I'll take the NOS cancel cam and spring kit
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 09-14-2022, 08:51 AM   #3
Classic Bowties
Okay, the total and payment info for sending of funds via paypal has been forwarded on Wed. 09/14,
please confirm your full shipping address and we'll get the parts ready for shipment. Thanks, Mel
Old 09-15-2022, 01:00 AM   #4
Classic Bowties
Your column parts have been shipped off, the package went out via USPS first class on Wed. 09/14 and your expected delivery
day is Mon. 09/19. Thanks again for your order and let me know if we can help with any other 67-72 parts needs. Mel
Old 03-03-2023, 11:17 PM   #5
CKfan
Originally Posted by Classic Bowties View Post
We can offer/supply the upper rubber washer bushing and the lower plastic wear bushing both in GM NOS, if interested post a reply in the below linked column parts f/s thread and we'll get the two parts pulled out and pictured for you. Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=838093
Need the upper rubber washer bushing if you have one. $?
CKfan is offline   Reply With Quote
Old 03-04-2023, 02:28 AM   #6
Classic Bowties
CKfan, here are the requested wear parts for your 1969 non-tilt 4 speed/floor shift steering column, am just now seeing that you've found the lower plastic wear bushing after taking these pics so disregard the NOS plastic bushings, we can offer you the upper rubber washer bushings in GM NOS for $15. ea + $6. for CONUS shipment. Lmk, Mel
Old 03-04-2023, 12:51 PM   #7
CKfan
Will take 1 upper bushing rubber please.
Thank you for the response.
Old 07-29-2023, 05:52 PM   #8
lkt1954
Do you have any of the brackets that hold the column to the dash?
lkt1954 is online now   Reply With Quote
Old 07-29-2023, 06:04 PM   #9
Classic Bowties
Yes, we can get a set of OE used steering column install brackets headed your way, let me grab you some pics and pricing. Mel
Old 08-04-2023, 12:17 AM   #10
Classic Bowties
We just got the OE steering column install hardware/bracketry pulled out and listed in the below linked parts board f/s thread. Have a look and let us know, Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=846472
Old 08-06-2023, 11:34 AM   #11
chev-obsession
chev-obsession's Avatar
I will take one NOS lower tilt column bearing
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 08-06-2023, 12:48 PM   #12
Classic Bowties
Okay, the total and payment info for sending of funds via paypal has been forwarded on Sun. 08/06, please confirm your full shipping address and we'll get the part ready for shipment. Thanks again, Mel
Old 08-07-2023, 11:28 PM   #13
Classic Bowties
Your GM NOS lower column bearing has been shipped off, the package went out via USPS ground advantage on Mon. 08/07 and your expected delivery day is this Wed. 08/09. Thanks again for your order and repeat business, let me know if we can help with any other 67-72 parts needs. Mel
Old 08-15-2023, 01:46 AM   #14
Classic Bowties
Adding this new repro tilt column 4 spd/overdrive shift indicator dial lens for member steves1967, will offer the shift lens to you for $15. shipped and our payment options are listed in the first post at top of thread. We also have the matching tilt column specific shift indicator pointer and shift indicator lens housing available in new repro and can combine ship all if needed. Mel
Old 08-15-2023, 07:41 PM   #15
Classic Bowties
sloGMC, here are some pics of the OE used tilt column shift indicator dial lamp steel cap & plastic filter setup that we can get headed your way, the other lamp cap/filter set marked sold has been shipped off to member Richard. The lamp filter parts are $25. + $7. for CONUS shipping ***Qty. 5 Sold/Shipped***, the total and payment info for sending of funds have forwarded on Tue. 08/15, please confirm your full shipping address and we'll get the parts ready for shipment. Thanks, Mel
Old 08-16-2023, 10:08 PM   #16
sloGMC
sloGMC, here are some pics of the OE used tilt column shift indicator dial lamp cap/filter setup that we can get headed your way, the other lamp cap/filter set marked sold has been shipped off to member Richard. The pair of lamp filter parts are $25. + $6. for CONUS shipping, the total and payment info for sending of funds via paypal has been forwarded on Tue. 08/15, please confirm your full shipping address and we'll get the parts ready for shipment. Thanks, Mel
Thank you. Since it appears I actually do have one installed in my tilt (albeit, amber) I will pass for now. I would feel bad hoarding two.
1971 Pontiac Firebird
1971 GMC C2500
sloGMC is offline   Reply With Quote
Old 09-04-2023, 10:45 AM   #17
gdelaney5
Junior Member
Mel,
I am interested in a set of any NOS internal components that you still have for non tilt automatic steering column. Could you provide a list and $ for what you still have available?
Thanks! Greg
gdelaney5 is offline   Reply With Quote
Old 09-05-2023, 11:24 PM   #18
Classic Bowties
Originally Posted by gdelaney5 View Post
Mel,
Thanks! Greg
Hi Greg, to save a bit of time on our end let us know which wear parts you are chasing and I will reply back with availability and cost. Going off of memory for your column shift non-tilt steering column, we have the NOS upper & lower bearings, NOS lower bearing spacer mount, NOS lower bearing tension spring, NOS upper plastic and rubber bushings, NOS horn contact t/s cancel cam and the NOS turn signal switch and harness. Also pending confirmation of the actual year of steering column that you are working on, we may have the NOS shift indicator pointer, NOS shift indicator lens housing and both NOS chrome shift and turn levers. Let us know, Mel
Old 09-06-2023, 09:43 AM   #19
gdelaney5
Junior Member
Mel,
My column is for a 1972 k10
I will take:
NOS chrome shift levers
NOS chrome turn lever
Thanks,
Greg
Old 09-07-2023, 02:42 PM   #20
EdwardSams
Mel, you did it again. The parts arrived quickly and beautifully packaged. Amazon could learn a thing or two from you.
Thank you.
EdwardSams is offline   Reply With Quote
Old 09-08-2023, 07:22 AM   #21
gdelaney5
Junior Member
Mel,
In addition to my list above, if you have a 4sp overdrive lens for the 72 column I will take one of those as well.
Thank you,
Greg
Old 09-08-2023, 12:00 PM   #22
pjmoreland
pjmoreland's Avatar
****EDITED**** I'm after part number 3916047/474102
I'll take one of these, please, if available.
#4 / NORS horn contact pin, spring & retainer kit. $20. ***Qty. 3 Sold/Shipped*** Have more on hand/available...
Also, please let me know if you have a 3900514 upper spring for a tilt column. Thank you.
pjmoreland is online now   Reply With Quote
Old 09-08-2023, 01:28 PM   #23
Classic Bowties
Okay, we got'ya down for one three pc. #4/NORS horn contact pin, spring & retainer kit, I still need to get to gdelaney5's above column parts request and will check on the tilt only upper cam spring for you next. I can confirm that we do have the 3900514 springs on hand in both GM NOS and OE used, but we always seem to be chasing these often missing/hard to find cancel cam springs for our own tilt column builds. While checking on our available on hand tilt cam spring quantity, would you need/want the upper tilt column specific horn contact t/s cancel cam in either GM NOS, OE used or new repro? We have all three tilt cancel cam options on hand/available ready to ship and these small column parts can all be combined and sent out for the one $7. shipping charge. Let me know, Mel
Old 09-08-2023, 01:36 PM   #24
pjmoreland
pjmoreland's Avatar
I've already got the tilt horn contact t/s cancel cam, but it's missing the horn contact pin/spring/retainer.
Sounds great. I prefer OE on the 3900514 cam spring, if you've got it, but NOS will work, too. Thank you.
Old 09-11-2023, 04:21 PM   #25
pjmoreland
pjmoreland's Avatar
In addition to this...
and this...
OE (preferred) or NOS tilt column 3900514 cam spring
I'm also looking for this:
Clutch pedal push rod for a 2WD SBC
Any chance you might have one?
