![]() Join Date: Sep 2001
Protect-o-plate help
I bought a low-mile original '72 C20 that came with the original warranty booklet and Protect-o-plate (see photo). The VIN of course matches, but I was able to match the engine and transmission numbers shown as well. However, I'm not sure what the "D1H" means. I suspect the "R" is for a Rochester Carb, and the "C" is probably the production month. Please share any help.
![]() Join Date: Apr 2005
Re: Protect-o-plate help
What color is the interior?
The D1H I believe is the axle code, but I don't know for certain.
The lid is stuck on my jar of anti seize Last edited by geunther; 10-13-2022 at 10:07 AM. |
I'm trying....
![]() Join Date: Oct 2013
Is it a Dana or Eaton rear axle?
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
I'm trying....
If you've got the build sheet...box 17 (or thereabouts) will be an axle code. You can see if that syncs up.
![]() Join Date: Sep 2003
Edit... In your case the Transmission ID is under the VIN and the Rear Axle code is under the engine. I've seen other POPs that have those positions swapped, in which case the picture below would be correct.
I believe your trans is build date of February (B) 23rd. Engine is Feb 29. Truck build month is March (C). I'm not sure what D1H stands for. Seems to be a common number sequence for many trucks though looking at the build date thread. Would you be willing to post that on the build date thread? Last edited by 402Bowtie; 10-13-2022 at 01:42 PM. |
#6 | |
The truck is Black/Black.
![]() Join Date: Feb 2000
Sorry if this is a hijack but I found this kind of interesting. I saved this Protect-o-plate from a junked out '72 Blazer with delivery date of 5/23/72.
V1116TDB is the engine- V: Flint, Mi, 1116: Nov 16, TDB: 307 RAWW321 is the rear axle code- 3.73's RAW: 3.73, W-Warren, 321- 321 day of the year. N2S12 is the trans code- SM465 4 speed and it looks like the little bowtie next to the 'K' may mean it was a Chevy K-series (4x4). Not sure what the single 'B' is for.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#10 | |
The B is for Bay City (1 bbl/ 2bbl) and refers to the carburetor source. I'm not sure why your axle code format varies from the OP's. A decent amount of trucks received the D1H notation. Last edited by 402Bowtie; 10-14-2022 at 11:31 AM. |
Makes sense- K is the 11th letter so it would be November for a build month and that would line up with the engine build date being in November as well. This was a Blazer and got a GM 12-bolt rear axle, the OP's got a Dana axle, may explain the D1H axle code?
