10-16-2022, 01:38 AM | #1 |
Dealer added spotlight wiring.
The new truck a picked up has two original dealer added spotlights. They were unhooked and I attached the drivers side to the circled plug only for it to blow out the 15 amp fuse under it. Where were these originally connected? I need two plugs. One for each light. Thanks.
Posted via Mobile Device |
10-16-2022, 11:40 AM | #2 |
Re: Dealer added spotlight wiring.
I don't know the answer but, I do know that's one cool truck!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-12-2022, 09:26 PM | #3 |
11-13-2022, 12:46 AM | #4 |
Active Member
15A seems like quite a lot for a spot light, considering that headlights only use about 3 amps each. I would check out the wiring to your spot lights for a ground/short somewhere. I don't know where they would be originally wired in but I think those male spade connectors were often used for dealer accessories.
1971 Pontiac Firebird 1971 GMC C2500 |
11-13-2022, 11:28 AM | #5 | |
11-13-2022, 11:47 AM | #6 |
Darn...I really wanted to help! My '72 Suburban has dealer installed dual spotlights as well, but my original fuse block is a mess! Both spotlights works, and my fuse block also has two male spade slots right above the spotlight fuse you used...except my 15A fuse is missing from it's holder??? The top male spade slot (fuel ga) has a "one wire" connector in it (the one under it does not) with the same size and color (off white) as the wires running to the spotlights...but that single wire gets lost in a bundle that appears to go to a multi wire connector that goes to another multi wire connector that gets lost again by going behind the fuse block??? Like I said, a mess, but everything works? Rewiring is on my list, so one day I might understand what/why the original owner did what he did...but for now I would guess that something with the spotlights shorted out and his fix was to remove the fuse and find power from somewhere behind the fuse block? Maybe your "previous owner" had a similar issue and that's why the fuse blows??? I don't believe I helped you much, but YOU helped me realize that I need to put rewiring to the top of my list...while everything is still working!
Woody Last edited by Beach-Burban; 11-13-2022 at 11:59 AM. |
