10-17-2022, 04:16 PM | #1 |
How is glove box emblem attached on 1968 Chevy C10?
How is the Chevrolet glove box emblem attached on a 1968 Chevy C10?
10-17-2022, 05:15 PM | #2 |
Re: How is glove box emblem attached on 1968 Chevy C10?
I glued mine on with some of this - https://www.amazon.com/E6000-237032-.../dp/B004BPHQWU
10-17-2022, 05:58 PM | #3 |
I've also used the 3M trim tape - its double-sided.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-17-2022, 06:00 PM | #4 |
X2 on the double sided tape. Mine has led for 20+ years.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
10-17-2022, 06:17 PM | #5 |
Roadtrip!
To answer the OPs question, i believe it has 3 barrel nuts holding it on.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
10-21-2022, 06:23 PM | #6 | |
Does anybody know? Are there just push pins holding the emblem on and you just pop it off the glove box door? It is a factory stock glove box door for 1968 C10 |
10-21-2022, 08:34 PM | #7 |
Roadtrip!
Maybe i should say a barrel clip. They do not go through. They expand inside the door when the pins are pushed into them. To pull the emblem, gently work it off with a thin flat bar. Sometimes the pins will break on plastic emblems.
10-22-2022, 09:26 AM | #8 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
10-22-2022, 10:16 AM | #9 |
Does anybody have pictures of how the factory did it? I could swear when I took the emblem off my door it was glued on from the factory. There were not any barrel clips. The pins on the replacement emblems are tiny, compared to other emblems that use barrel clips, and the emblem is plastic unlike the others.
10-24-2022, 01:09 PM | #10 |
Is you door like this one, with this emblem? I bought this one to restore, and noticed that there were barrel clips in it. They were pulled out as I went a different route with it.
10-24-2022, 01:11 PM | #11 |
I finished mine off to match the bed wood as best I could. Then I applied this Chevrolet scrip emblem with the double sided 3M tape - hoping up very well.
