10-19-2022, 06:02 PM | #1 |
01 check engine light...Need help with code P0171/P0174
I have a 01 Chevy step side with the small V8 engine that is displaying the code P0171/P0174 which designates a lean running condition. Under remedies they list about 6 causes that causes this code. I have had a mechanic replace the fuel pump. One replaced the MAF sensor. It can get expensive going down the list replacing parts hoping that this replacement part will fix the problem.
Anyone have this same problem? Would like to hear what it was that you did that eliminated it running lean and kept the check engine light off! Thanks in advance. |
10-19-2022, 07:50 PM | #2 |
Re: 01 check engine light...Need help with code P0171/P0174
https://www.youtube.com/watch?v=tPZb1uWu9oo
Start with: South Main Auto it one of the great information sites. https://www.youtube.com/watch?v=3BquA8x4LMU This is where you need someone experienced at reading more than codes. Bet this helps. Cheers. |
10-24-2022, 07:14 PM | #3 |
Moderator
P0171 is Bank1 lean
P0174 is Bank2 lean You're going to spend a ton of unnecessary cash loading the parts cannon and blasting parts at it. Since it's both banks I'd start by checking your fuel pressure at the test port on the engine. It could be O2 sensors but both banks failing at the same time is not a normal failure mode.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-24-2022 at 07:20 PM. |
