Old 10-25-2022, 09:45 AM   #1
Speedracer39
Speedracer39's Avatar
Body bushing replacement
Im getting ready to order complete body and radiator support bushings was wondering who has the best and complete kit that has worked out with out a issue? Thanks
Speedracer39 is offline   Reply With Quote
Old 10-25-2022, 10:19 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Body bushing replacement
Classic parts , You'll also need core support mounts , Don't buy urethane unless you like squeaking
https://www.classicparts.com/1967-72...ctinfo/35-145/
Old 10-25-2022, 10:26 AM   #3
LNP
Agreed this is where I got mine. Both kits were complete with all hardware and shims if needed. Heres the link for the radiator support kit
https://www.classicparts.com/1969-72...ctinfo/78-635/
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 10-25-2022, 10:34 AM   #4
Speedracer39
Thanks ,for the quick response, I’m going to get them ordered
Old 10-25-2022, 11:34 AM   #5
Accelo
Accelo's Avatar
I may over-tightened mine and the rubber split.
One thing the imports never get correct is the durometer of the rubber.
The replacement mounts were also cone shaped, didn't look anything like the originals.
I know Frank's Pickmups carries two different sets.
One is OEM quality?
Cheers
Accelo is offline   Reply With Quote
Old 10-25-2022, 12:13 PM   #6
Speedracer39
One is OEM quality?
Cheers
Thanks for your input I’ve never heard of Frank's Pickmups
Old 10-25-2022, 12:18 PM   #7
68 P.O.S.
I bought mine (rubber) from Classic Heartbeat. Great quality
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-25-2022, 05:19 PM   #8
Accelo
Accelo's Avatar
Both Franks and Classic Heartbeat are located in Olympia WA.
Franks sells on this board but to my knowledge doesn't do internet sales.
At least as far as I know.
Old 10-25-2022, 05:40 PM   #9
LNP
The kits I got from Classic Parts was good quality stuff and I had zero issues. Been drivin the truck for two years still all good.
Harley
Old 10-26-2022, 12:02 AM   #10
PbFut
I just did a test fit setup of the radiator support this week. I sourced new radiator support to frame bushings from Classic Parts. You only need one kit. It has a set of two bushings Fit was exact to the ones on my 72 but cannot confirmed they were original. I had to cut the ones on the truck out due to very bad corrosion. Parts on the truck were not really identifiable until I saw the new kit. All the parts needed are in the set and appear to be of reasonable quality. I will echo the opinion of rubber over urethane. The harder Urethane will provide zero improved benefit unless you are looking for every last drop of chassis performance for racing and don't care about noise and harsh ride.
PbFut is offline   Reply With Quote
