Dual Pass Radiator for my 68
Presently I have a standard aluminum rad in my 68 C10. I have an LS engine in it and because of the waterpump outlet position (Same as 2006-07 1500) I have that super long rad hose extending from the pump on the passenger side all the way over to the drivers side rad inlet. I also had some issues with the trans cooler fittings and decided to put a dual pass rad in. Does anyone know of a manufacturer of a dual pass direct fit rad for my truck?
Thanks for any suggestions. Jim |
![]() Join Date: Dec 1999
Re: Dual Pass Radiator for my 68
I have one of these:
https://www.ebay.com/itm/352233489480 It was cheap, there are other more expensive ones out there. |
I don't have a part number but I used an Afco dual pass on my 68 LS swapped. Biggest I could fit. Got it from Speedway Motors. I had to weld in a bung for the coolant line.
Here's a pic. |
#4 | |
I'll check out Afco as well thanks! |
