Old 11-10-2022, 05:34 PM   #1
ViatminC10
68 Mustang Tank in 63C10? Ohm Sending Unit Rating??
Anyone installed a 68 Mustang 18 gallon tank in bed of our trucks?
Then sending unit ohms reading for this tank is 75 ohms empty and 10 ohms full.
I have read that our gages are set up for 0 ohms empty-30 ohms full.
Can the sending unit in the 68 Mustang be modified somehow to work with our original gages?
Thanks in advance!
ViatminC10 is offline   Reply With Quote
Old 11-11-2022, 05:36 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 68 Mustang Tank in 63C10? Ohm Sending Unit Rating??
0-30ohm I bet you could make this work. https://www.tanksinc.com/index.cfm?p...d=62&mode=prod
Old 11-11-2022, 10:31 PM   #3
LVPhotos
LVPhotos's Avatar
That tank fits 60-62 frame but don't think the 63-66 would work. Try Tanks Inc for narrower tank. Check faq page.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-13-2022, 07:20 PM   #4
ViatminC10
Was hoping there would be a relatively cheap way to convert the sending unit to read 0-30 ohms for our trucks.
I'm thinking this might be the way to go. I seem to recall someone used one of these 50 chevy passenger car tanks that already comes with a 0-30 ohm sending unit. What d ya'll think???
https://www.ebay.com/itm/36113940826...Bk9SR7Tvi7WOYQ
Old 11-14-2022, 05:29 AM   #5
The Rocknrod
Moderator
Contact Vin63 here on the forum. He used to build custom fuel sending units. Maybe he still does.
Also a member lakeroadster installed a 50's Chevy Passenger car tank halfway down the page - https://talk.classicparts.com/thread...wb-step.13928/
You can get the tanks at http://www.tanksinc.com
Not sure if a Camaro tank would fit - http://67-72chevytrucks.com/vboard/s...d.php?t=448386
Old 11-14-2022, 02:57 PM   #6
ViatminC10
thanks so much for that info!
Old 11-14-2022, 08:36 PM   #7
AcampoDave
AcampoDave's Avatar
I really liked Tanks Inc and they were helpful when I did my tank swap. Maybe they have a universal one that will fit your tank choice. They did for mine. I think it was the one that Rockinrod linked.
AcampoDave is offline   Reply With Quote
Old 11-17-2022, 01:21 PM   #8
The Rocknrod
Moderator
There is a company that repairs sending units, they might help - https://tristarrradiator.com/services/
