11-10-2022, 06:46 PM | #1 |
WTB POWER Steering pump
mine leaks I don't need the brackets would like it with pulley attached also will buy new if someone has a part # I looked at JEGs and Summit not sure if they are compatible I have 1967 SBC 327 camel back heads my original brackets bolt up nice to the block and Motor mount I don't want to change mounts I have a pump off a 305 different set up won't work with my brackets thanks in advance
Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-10-2022, 08:56 PM | #2 |
Re: WTB POWER Steering pump
These are rebuildable, and kits very reasonable. The only special tool is to pull the pulley, and available for "loan" at most parts stores. I was going to rebuild one recently, but found the shaft and bearing was very worn. someone had ran the pump dry, and kept running apparently, but I found a used one at a swap meet. There are some you tube videos on the rebuild. In case you want to tackle and save a few $$ like me, and avoid some of the junk rebuilts.
11-10-2022, 10:04 PM | #3 |
Thanks I think the tank itself is leaking not sure and not sure how to test that
11-11-2022, 12:50 PM | #4 |
"Trucks with Class"
Check with CPP and others for new tanks. New pump kits come with the O-rings, and that usually cures them.
11-11-2022, 12:52 PM | #5 |
I did this a m and purchased new thanks very much to all
11-13-2022, 02:08 AM | #6 |
I think I have that, I will send you pic tomorrow.
