Edelbrock Pro Flo 4 and Sanderson BB8 Headers Project
Sorry in advance for the lenghty rant just to ask one question!
No matter how much effort I put into getting prepped to do a project, something jumps out to derail me a bit...which is to be expected when mixing old with new, I suppose! It took me nearly 10 months to receive my EFI kit, and having done much of the preliminary work, I decided to have headers installed for me at the same time that I was getting the O2 Sensor Bung welded into my exhaust. Before purchasing the BB8's, I followed Sanderson's instructions about verifying that I actually had the original Big Block motor mounts installed...and thanks to Lock Doc's pictorial post, I was able to determine that I did in fact have the "year specific" motor mounts installed under my 454 in the forward position (there are only two positions, right?). My '72 Suburban originally came with a 350 Small Block, but the original owner (who worked for a GMC/Chevrolet truck dealership as Service Manager for over 45 years) used the correct '72 Only Big Block motor mounts when he did the transplant...so I believed I was golden. Not the case when the BB8's install was attempted by my "Header-Pro" and I was quickly called and given the bad news that the passenger side collector was hitting the frame and not allowing the mounting flange to seat against the head (driver side was not even attempted at this point). I did some more research and found an interesting write-up along with some pictures from when Sanderson developed and test fit the BB8's using an original Big Block truck. If I'm not mistaken, the Big Block truck they used was a '68 to '71 version...and they even showed that a cresent shape was ground out for the fittment of the motor mounts??? I'm confused by two things (actually a lot more than two but at this moment, I'll address the two): 1) Does Sanderson know that in '72, GM had a "one year only" motor mount for the Big Block trucks? And 2) Doesn't grinding an area of the frame negate the idea of designing headers that actually fit this application? Both questions are rhetorical, but you get my point, right? Now I have also read that there was a design change early on, so that could explain no longer having to grind the frame...which leads to my actual question to the much more experienced board members: Do the '68 to '71 Big Block motor mounts position the engine higher than the '72 only Big Block motor mounts? A higher fit is what my header-professional said was needed. At this point, I'll have to wait until my EFI is up and running before raising the 454 up (and possibly out) to determine what needs to be done to fit the headers...but I did get the O2 Bung welded in place after the passenger side exhaust manifold was reinstalled. Am I missing something obvious??? I'll add some pictures, but please ask questions if you think I'm overlooking something! Thanks for any thoughts you might have. Woody Collector contacting frame. Gap between flange and head...primary tube contacting motor mount stand. Passenger side motor mount stand. Crappy side view picture of motor mount. Driver side motor mount stand. |
Re: Edelbrock Pro Flo 4 and Sanderson BB8 Headers Project
First three photos credit to Lock Doc...Thanks Leon!
Obviously what I have. Will these raise the engine? Obviously what I don't have. Does this spacing appear to be correct for the Big Block? At least I got my O2 Bung installed!!! Woody |
Who Changed This?
![]() Join Date: Jan 2013
Lots of troubles, hope they get straightened out. My '70 BB truck has an HEI; the cap is a little over 4" away from the firewall. I have the opposite problem- my fan is very close to the radiator- the front edge is 1-1/2" away. It's always been like that, for the 41 years that I've known this truck. I finally just built a custom shroud for it. I was looking at the Blueprint Engineering 496 stroker, which is based on the 454. I wouldn't be using headers, but your problems give me pause on that kind of purchase.
#4 | |
Woody |
#5 | |
Who Changed This?
#6 | |
Woody |
I never had an original BB truck but I thought the style in your first pic started in '73 models.
I had a 67 that I installed BB on the SBC stands. The headers didn't fit and there was plenty of grinding on the frame and hammer work on the pipes. In the mid 1980's I wanted to install another BB in a '72 and went to the dealer and purchased the stands you have in the second pic. Yes it moved the engine up and forward.
Beach-Burban,
As @Bigdav160 mentioned, the mounts in the first image are what I thought were post-72 mounts & the 2nd image is what I always understood were for 68-72's. They're what I used for my BBC swap in my 67/68 mothballed project. LocDoc knows his history but I researched/learned about the mounts before doing my swap & never was told there was a '72 only' frame stanchion/mount. Interesting to learn this. Back when I did my BBC swap, Sanderson didn't make the BB8 headers for trucks. I used the BB3's for 68-72 Chevelles. I had to trim minimal amount from the edge of the frame rail (~.1875-.250"?) where the collector is located. I just wanted to share what I did.
#9 | |
I've heard that the BB3's would work, but I went with the BB8's as they are made for our application...and should not have been an issue at all!!! I am curious if the 67/68 BB project of yours used a 67 or 68 frame? If 68, I understand the minimal trimming due to using BB3's...but if you used a 67 frame, I would have thought that a tremendous amount of work would have been required? I've said it many times...I'm no expert (unless asking questions is an art form) ![]() Thanks again! Woody |
#10 | |
#12 | |
Believe me...I'm no expert with regards to any of this, but I also read that because a BB wasn't available until sometime in '68, '67 frames need a lot of work when swaping in a BB with headers no matter which mounts you use? So they sold you '68 to '71 mounts for a '72...that's interesting! I wonder if they knew that you would have less issues with the older mounts? Exactly my question! Thanks Bigdav...I really appreciate your input! Woody |
At the body shop.
Those 72 only look an awful lot like squarebody stuff.
I thought our 68 was on squarebody mounts, but maybe they're 72 mounts.
" That didnt make it any newer " " Dont antique the equipment " |
#14 | |
Woody |
#15 | |
Beyond that, what about making some flat spacers that can be inserted between the MM pad & block?
#16 | |
Spacers aren't a bad idea, but that seem like it would take about the same amount of work as replacing with the proper mounts? Thanks again. Woody |
#17 | |
If you're not sure the mounts (stanchions) are the Golden Ticket you seek, you're still potentially stuck. To me, that would be frustrating. Say the 'new/different' stanchions allow the headers to fit but now the fan doesn't line-up or a valve cover interferes w/something (common issues when using different parts). Thus my suggestion of tweaking things to work w/what you have since the drivetrain is already installed/in-place. I get it if you don't wish to go that route. If someone had both types & would let you try the set-up that's pre-73 big-block (but different from yours) to see if that solves the issue, that's 100% how I would go about it first. Barring that and/or wanting to move forward sooner than later, I'd tweak things. I wish I could help & will definitely be watching to see what the answer is to your dilemma.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-07-2022 at 04:37 PM. |
#18 | |
At the body shop.
There's some hackery on the driver's side rail..
#19 | |
Woody |
#20 |
***Update***
Well...it appears I need to back-peddle a little on who screwed up with the fitment of the Sanderson BB8 headers! My mechanic friend (Jerry) finally got an area in his shop freed-up so we could start to figure out the motor mount issues, and after removing the stock manifolds and fitting in the passenger side ourselves, (this was the side that my so-called "Header Pro" provided pictures showing really bad interference with the fit), we slid the header in without issue??? Sure, it was a little close between the frame and where the "Sanderson Headers" nameplate is welded to the collector...but we still fit it in even with a rag in-between protecting the finish! When we took another look at the pictures that the "Pro" had sent me, we realized that he had attempted to install the header while aligned with the wrong bolt hole (which pushed the header forward nearly 1 1/2 inches)!?!? Now the primary tube easily clears the "single bump" in the middle of the motor mount perch. We will be grinding a little extra clearance into the frame where nameplate is...but it's not absolutely necessary...just preferred! Then we started working on the drivers side (which the "Pro" never attempted as he couldn't fit the passenger side). At first glance, everything looked like smooth sailing...although it really helped having the Suburban up on a lift as this side goes in much easier from below! The header flange mated-up to the exhaust ports perfectly until we tried to get the bolts started? After a lot of attempts, we managed to get the rear bolt started, but just barely...and then we realized that the alternator bracket was keeping the front of the header flange from seating tightly against the front exhaust port! There was nothing unusual about the stock alternator bracket or bolt, so we surmised that someone at Sanderson forgot to grind a clearance divot into the flange!? We struggled with the two options: grind the alternator bracket or grind the ceramic coated flange??? Ultimately, I made the hard decision and chose to grind the flange as the interference also involved the head of the bracket bolt (plus, the hole in the bracket would have to be made into a slot!). It wasn't just a slight divot that was required as we ground in small amounts until we got the header bolts to finally thread in nicely. Jerry (the shop owner) had some actually customers to take care of, so we called it quits for the day...but we had made tremendous progress without having to lift the engine, alter the motor mounts (although we are putting in a new set of "caged" rubber mounts) or dent-up these beautiful ceramic headers...just a little grinding in a couple of inconsequential places. It was a really good day! Woody This area of Jerry's shop is a little tight, but it has everything I needed including a lift and a complete locking security cage surrounding it (PLUS...Jerry!). Three things to note in picture: The bolt hole to the right of the flange that the "Pro" used; How much clearance there is when the primary tube isn't sitting on the "bump"; and the area with the purple rag...that will be slightly clearanced for the nameplate. This picture was supplied by the "PRO" and it shows how the primary tube is resting on the "bump"...because the flange is 1 1/2 inches too far forward! This picture shows how only a slight amount of grinding will be required to fully clear that retangular nameplate: A little by the purple rag and a little where the frame comes to a point. This picture was also supplied by the "PRO". It's a little hard to see but it shows that the "point" on the frame hits in the middle of the nameplate, however, as shown in the previous picture with the flange properly aligned and rotated into place, it has just enough clearance to bolt in! Last edited by Beach-Burban; 02-15-2023 at 08:07 PM. |
#21 | |
#22 | |
Woody |
#23 | |
#24 | |
Woody |
#25 |
***DRIVER'S SIDE PICTURES***
Notice where the alternator bracket and bolt required a divot in order to fit. Other than that, no clearance issues at all! Plenty of clearance for the frame and oil filter! Nice new "caged rubber" motor mounts waiting to be installed...although it was unfortunate that I couldn't find any "Made In USA" that would fit! Woody Last edited by Beach-Burban; 02-15-2023 at 08:05 PM. |
