12-01-2022, 03:00 PM | #1 |
Specs for rear differential
Hello
I have searched the forum and have found various answers I also have the 60-66 assembly manual but it does not have these answers I powder coated the rear axle and want to assemble back to stock, not changing anything. 1962 235 I6 C10 long bed 10 bolt What is the backlash ? .007 give or take a thousandth?? What is the pinion nut torque? What is the cover plate torque? What is the opposite side torque, the part the pinion is installed in? Thank you for any help |
12-01-2022, 09:35 PM | #2 |
Re: Specs for rear differential
Truck 10 bolt from a later year squarebody, or stock 62 HO32? If it's a squarebody rear, you just might be searching in the wrong spot. Please post a picture to help us help you
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-02-2022, 02:40 AM | #3 |
Here are some pics.
I believe and hope it is the 62 stock one. I never took one complete but only as I stripped it down. Like I said it went to get powder coat with the rest of the chassis and suspension. Let me know what you think it is and appreciate the help with the specs |
12-02-2022, 08:05 AM | #4 |
Looks like the stock Eaton HO32/33. I think those specs are in the Service Manual. I’ll look later today.
Posted via Mobile Device |
12-02-2022, 08:12 AM | #5 |
Moderator
This may help? - http://www.67-72chevytrucks.com/vboa...14&postcount=3
12-02-2022, 12:04 PM | #6 | |
12-02-2022, 07:44 PM | #7 |
Thank you everyone who responded, very helpful. I appreciate it. I will get the shop manual to verify everything and should be a good resource for the rest of the build.
Thanks |
